Diegoboy's Mini Budweiser
  • IONY
    • Jul 2008
    • 36
    #31
    well i use this servo and yes it is a smole one
    • IONY
      • Jul 2008
      • 36
      #32
      i want to change with this micro
      • Diegoboy
        • Mar 2007
        • 7245
        #33
        *Dimensions: 20.9mmX11.4mmX22mm
        *Operating Speed (4.8V no load): 0.10sec/60 degrees
        *Stall Torque (4.8V): 10.2 oz/in (0.7 kg/cm)
        *Temperature Range: -30 to +60 Degree C
        *Dead Band Width: 7usec
        *Operating Voltage:4.0-7.0 Volt
        Ya. I'm sure you need a new servo, not a new rudder.
        My servo has 39 oz-in (2.8 kg/cm). as opposed to your 10.2 oz/in (0.7 kg/cm)
        Want to sell your old rudder?
        • IONY
          • Jul 2008
          • 36
          #34
          Nop i will try with the new servo
          • Meniscus
            Refuse the box exists!
            • Jul 2008
            • 3222
            #35
            Lol!
            • HOTWATER
              • Nov 2008
              • 2323
              #36
              Diego, you are hillarious!!
              Very cool Mini Bud! I love it!!
              -Kent
              "Will race for cookies!"
              IMPBA D12
              My Gallery: http://forums.offshoreelectrics.com/album.php?u=1738
              • Diegoboy
                • Mar 2007
                • 7245
                #37
                I'm going to have a hard time with the current decals. They are under the clear coat.
                • egneg
                  • 4664
                  #38
                  Diego I was thinking (no it didn't hurt). If the plastic hull is red all the way through. Try some citrus strip and it may remove the clear and the decals leaving you with a red hull.
                  IMPBA 20481S D-12
                  • Diegoboy
                    • Mar 2007
                    • 7245
                    #39
                    It's Fiberglass.
                    • egneg
                      • 4664
                      #40
                      Well then it sounds like a repaint - bummer.
                      IMPBA 20481S D-12
                      • Diegoboy
                        • Mar 2007
                        • 7245
                        #41
                        Maybe just the upper half
                        • tylerm
                          • Nov 2007
                          • 310
                          #42
                          Watch those fibreglass hydros like that- i have seen the big ones split open and all the hull was was a vac-formed plastic shell with a layer of fibreglass inside
                          • Diegoboy
                            • Mar 2007
                            • 7245
                            #43
                            Tylerm I can assure you that this hull is Fiberglass (except for the cowl exhaust part)
                            • domwilson
                              Moderator
                              • 4405
                              #44
                              You'll have video of this before you post it in the swap shop, right?
                              Government Moto:
                              • Diegoboy
                                • Mar 2007
                                • 7245
                                #45
                                To Domwilson (after a video run)
