Building up the Blackjack 26 bl
  • RCvolt
    • 22
    #31
    Those pics actually looks nice and calm until you realize what is under the water line
    I have gear on order similar to yours thus the special interest on my part. Doing a little at a time as budget permit
    Thanks for the update and looking forward to hearing more on your progress.
    • chunkymonkey28
      • Apr 2009
      • 58
      #32
      Wow man I'm sorry to see that thing so submerged! Very cool build though...I'll be watching this one :)
      • Blackjack-sven
        • Feb 2009
        • 371
        #33
        Ok I have the Feigao 8xl back in the boat and I'll be testing the Hydra240 tomorrow to see if she still works as the Spectrum Rx and servo survived. If the hydra works I'll test the boat again but this time I'll be returning the turn fins to their stock location. I'm putting them back because I put the boat back to it's previous working condition except for the fins and it still bounced around even after removing one entirely.
        HK Genesis, DF Vortex, Baja 5T, Lazer ZX-5 sp, XXX, 8T, P51-D Mustang Shangrila, GP Giant P51-D Mustang, Blade 400 3D, with way too many more to list.
        • Rumdog
          • 6453
          #34
          I'd remove both fins, they are useless on cats and will trip them up in the corners. try lowering your strut or moving the cg up a little bit.
          • z400
            • 1311
            #35
            Seal that hull man.
            Boat should have never took on water or sank like it did.
            Z
            KBB34" Mono - Fast
            ToySport Triton- Not as fast
            • bwells
              • Jan 2009
              • 842
              #36
              You just recently got the bj55 and if I remember correctly another boat after that, a Mono I think. Why not leave the bj 26 alone as you have the x642 and lipos and do up the bj55, How much time and money do you have? I want to see the bj55 match the 126 MPH as the Germans can do. Go for the gusto and the BIG guys
              • RCprince
                • Jul 2007
                • 1637
                #37
                If that BJ 55 does 60 you've gotten alot out of it, those hull are not made for speeds over 45mph max and can't turn above 35 with out flipping.
                • Blackjack-sven
                  • Feb 2009
                  • 371
                  #38
                  Originally posted by z400
                  Seal that hull man.
                  Actually the lid was sealed shut with tape but the force of the impact ripped it clean off.
                  • Blackjack-sven
                    • Feb 2009
                    • 371
                    #39
                    I intend on turning one of the 55's into an electric SAW. It may not survive after the first run but it will hopefully hold a record.
                    • Blackjack-sven
                      • Feb 2009
                      • 371
                      #40
                      Etti 150 opto ESC
                      I now have the boat setup with the Etti esc, Feigao 8xl, JR FM Rx, Futaba Digital servo, Octura x642 prop, and Trak Power 4900 Lipo's, and have re-routed the cooling lines to make them more effective and cleaner. But I am wondering why the ETTI has a secondary lead comming out of it? It can be removed but it does not tell me what it is used for in the Manual. can anyone tell me what it's used for? I thought it might be the bec but where on earth would I plug it into?
                      • Blackjack-sven
                        • Feb 2009
                        • 371
                        #41
                        any ideas?
                        • Boatman
                          • Jan 2008
                          • 796
                          #42
                          bec it appears. you should hook that to rx unit in the batt. slot. re-read instructions to be sure
                          • Blackjack-sven
                            • Feb 2009
                            • 371
                            #43
                            Thats what I thought as well but does the Etti not have bec capability? That and that the red and black don't coincide with the Rx pos and neg.
                            • Rumdog
                              • 6453
                              #44
                              Unplug it. it is a wire for using the etti datalogger.
                              • Blackjack-sven
                                • Feb 2009
                                • 371
                                #45
                                Thanx for the help. I removed before I read this as it didn't seem to work for anything. I also read that this esc does not have bec so I plugged in a batt pack and all is well now.
                                Now I just need a new flex shaft as the one I had does not fit the x430 prop.
