Prop Placement
  • Blackjack-sven
    • Feb 2009
    • 371
    What are you trying to achieve with a triple rudder configuration
    Douggie
    All about the looks and being different, and I'm guessing no one has ever tried this before so I will be able to do a write-up of how it works....if at all LOL.
    HK Genesis, DF Vortex, Baja 5T, Lazer ZX-5 sp, XXX, 8T, P51-D Mustang Shangrila, GP Giant P51-D Mustang, Blade 400 3D, with way too many more to list.
    • Flying Scotsman
      Fast Electric Adict!
      • Jun 2007
      • 5190
      A great response, as I like to be different also. I think I know the end result but give it your best shot.
      Douggie
      • DISAR
        • Aug 2007
        • 1072
        More rudders or bigger rudders do nothing more than adding more resistance hence less speed or more amps. Looking different and nice is accepted by all for sure, but why pull more amps or decrease speed? An idea would be to make the dual rudders narrower and very sharp at the leading edge to decrease resistance.
        http://www.rcfastboats.com/
        • detox
          • Jun 2008
          • 2318
          WOW...cool picture!
          I would also sharpen the bottom edge of each rubber... I mean rudder. This will prevent lift of transom while running boat.
          • Blackjack-sven
            • Feb 2009
            • 371
            How thin would you be talking about?
            The sharpening I would have done anyway, but I would never have thought about the lift factor on the bottom of the rudder. Good insight.
            I think I know the end result....
            What do you think it would be.
            As of now my setup will be the Octura x642, water jacket around a 2340kv motor, motor fixed to a water cooled mount, two aluminum rudders, one on either side of the transom with separate servos running them, turn fins mounted to the side of the hull to keep the rudders from hitting them, the stock rudder/out drive in the center, 2 Trak Power 4900 LIPO's in the center of the hull, as I found having the batt's in the lowest part of the transom makes for lousy cornering, a castle creations 240 Amp Hydra ESC, and spectrum RX with telemetry for on the go info.
            • Blackjack-sven
              • Feb 2009
              • 371
              Just ran the boat with this setup
              I just came back from Humber Bay Park after a quick run for speed and cornering tests.
              I ran the stock 1500 kv motor with 20 degree timing, a Castle Creations Mamba Max ESC, Stock running hardware, 2 4600 NI-MH Intellect batteries, a spectrum SR3300T RX with a temp sensor on the ESC.
              With this setup I got on plane nice and fast and recorded a top speed of 53 Kph on rough water, but with the batteries in the lowest part of the boat the turning was ridiculously unstable and I had to slow down a ton to keep her happy.
              The temp of the Mamba Max hit a high of only 120F, and I know from experience that if you run the Max systems at 200F you have roughly 5 min of run time before frying it, so I have a bit of room for a larger prop but not much at all. 160F is as far as anyone should go so as not to damage the controller.
              • old guy
                • Nov 2008
                • 687
                Originally posted by kookie_guy
                LOL! Ok but now you gotta help me with my original question.
                Lets get back on tophere I mean topic here
                more sh*t in the water the slower you go if you want it to look cool take here with you I'm sure evry one will look lol
                MMMMMMMMMMMM
                Old Guy
                • old guy
                  • Nov 2008
                  • 687
                  Hi I would fix the wires coming of your motor be for they
                  Old Guy
                  • hookedup
                    • 312
                    BJ26 with fullers long strudder
                    heres a few vids of my buddies BJ26 that had a fullers long strut/rudder set-up on a 9xl.
                    OPP Racing "Other Peoples Parts!"
                    Island Boys Fast Electrics
                    • ozzie-crawl
                      • Sep 2008
                      • 2865
                      here is a pic of my blackjack iam doing, will be running a 6xl on 4s
                      • Blackjack-sven
                        • Feb 2009
                        • 371
                        I finally picked out all my hardware and here are some pics of how it may look in the near future, so keep your minds open and let your imaginations run wild.
