scratch build: micro cat
  • Jesse J
    scale FE racer
    • Aug 2008
    • 7119
    thanks, I like the look, even if no use, of the spray rail (as you call it), I see people using names differently, but I think I agree with your terminology: two lift strakes and a liiiiiiiitle tiny spray rail along the outside. I used that architecture plastic in a 60deg triangle x section. easy to use, but also easy to screw up with CA.
    Thanks for the encouragement, it has been on hold recently and you've rekindled my drive to finisher up and see if she floats!
    "Look good doin' it"
    See the fleet
    • Avanti
      • Nov 2007
      • 1280
      Where did you get the architecture plastic? That sounds like the ticket for the strakes and chines. Did you use that for the spray rail too? I might get back at my manx soon too.
      • Jesse J
        scale FE racer
        • Aug 2008
        • 7119
        funny, I actually got it at the university bookstore (we have a pretty good architecture dept), but I have also seen it at LHS.
        I just used it for the spray rail. The problem with using it for strakes is that it doesn't come in less than 45deg triangle. I guess if you had a high precision band saw you could mill flatter stuff. For my strakes I did just that with balsa, I milled my strakes according to the plans from a poor chunk of trailing edge using my bandsaw at a high angle. For this guy, I happened to have these strips laying around from the last cat I made.
        Do you have a thread going for your manx?
        See the fleet
        • Avanti
          • Nov 2007
          • 1280
          yeah here's the link http://forums.offshoreelectrics.com/...highlight=manx
          • Jesse J
            scale FE racer
            • Aug 2008
            • 7119
            Originally posted by Norman2
            Hi Jesse J. Where did you get the plans. Thanks for your help.
            Norman2
            Turns out Shockerman is the designer and I have been given permission to distribute them to whomever would like. PM me with your email and I can shoot.
            See the fleet
            • Jesse J
              scale FE racer
              • Aug 2008
              • 7119
              maiden voyage
              well computers were giving me grief today so I took it upon myself to self remedy. I finished the microcat. Well not pretty paint and all, but got her hardware back on and buttoned up. Got permission from the community staff to use the microboat pond in our place here and gave her a toss.
              went with mystery motor and esc (shown above but hidden under the hatch). rudder is by Joe Solinger, the strut is my own ugly creation.
              Here are are some more pics of after the run. Video link is below.
              Analysis (definitely open for comment):
              - need to move weight forwards
              - need to drop strut a tad
              - prop up (I think it was a 27 mm)
              - level side to side balance
              - need to gather courage and use whole pond for nice wide sweeping full speed turns.
              Video: http://www.youtube.com/watch?v=hu5Z2J5H394
              See the fleet
              • Avanti
                • Nov 2007
                • 1280
                looks good
                she cavitates off the line like a stock sv27
                what prop are you running?
                • Jesse J
                  scale FE racer
                  • Aug 2008
                  • 7119
                  #23
                  Cavitation gone. traded for torque roll... The hopping on the corners is enhanced also. I was thinking longer rudder and maybe something to hook the front? any ideas?
                  second run, much better!
                  See the fleet
                  • H2OCamel
                    FAST ELECTRIC EVERYTHING
                    • Oct 2007
                    • 484
                    #24
                    This boat looks killer in person!
                    "Discussion is an exchange of knowledge; an argument, an exchange of ignorance." Robert Quillen
                    • Avanti
                      • Nov 2007
                      • 1280
                      #25
                      Damn that thing flat out gets it now. what changes did you make?
                      • ace028
                        • Aug 2007
                        • 952
                        #26
                        Wow, looks faster then my twin powered one. Great job!!!
                        Twin power =
                        • Avanti
                          • Nov 2007
                          • 1280
                          #27
                          ace you need 3s
                          • Jesse J
                            scale FE racer
                            • Aug 2008
                            • 7119
                            #28
                            I tell you, the only changes I made were, 27 to 29 mm prop, 5 mm lower strut, and actually a smaller battery, 1250 Rhino pack to a 1100 mah zippy (actually same brand different label).
                            I would like to get camel and his radar to get us a speed since my gps wont fit inside, but I am pretty sure we are over 20 mph.
                            Any ideas on how to neutralize the torque roll? I was toying with ideas about a one side trim tab to counter it?
                            also the turning hop, longer rudder?
                            thanks guys, it took longer than I thought, as always, but am pretty psyched about performance; Camel, wait till you see it GO in person!
                            Now just to paint it up.
                            See the fleet
                            • Jesse J
                              scale FE racer
                              • Aug 2008
                              • 7119
                              #29
                              What did you guys think of the rescue barge? Check out what I discovered it was capable of:
                              Kinda crazy, eh?
                              See the fleet
                              • ace028
                                • Aug 2007
                                • 952
                                #30
                                Maybe keep the same strut depth, but play with the angle of it. Just go with small changes at a time. I am jelous at your speed on a single with a 2 cell lipo, compared to my twin with a 4000mah 2 cell.
                                Twin power =
