micro scat cat
  • waynedawg
    • Aug 2008
    • 132
    micro scat cat
    hi
    just started my micro scat cat build this is my first build
    1 mystery d2632-3000
    2 hardwear homemade
    3 motor mount homemade
    it will run on lipos and the esc is a 30 amp mystery
    motor and stuffing tube are installed and the hardwear
    have to put the strut and the shaft and servo in yet
  • 10gauge
    • Aug 2007
    • 281
    Looking good so far. The Micro Scat Cat is a fun run, especially for very small ponds. In my setup I used: Ammo 28-3600, 3S1P/2100, Avionics 45, x430 (41mph)
    Mean Machine Cat: 9XL, 4S2P, CC120, M545 (50mph) -- DF22 Hydro: 8L, 3S1P/4500, CC120, x637 (49mph) -- M-1 SuperCat: 1521/1Y, 6S2P, CC240, x447 (61mph) -- SV27 Mono: stock setup, 14-cell/4200, x642 (42mph) -- Micro Scat Cat: 28-3600, 3S1P/2100, Turnigy 60, x430 (41mph)
    • waynedawg
      • Aug 2008
      • 132
      thanks we are running 2 or 4 of thease to race aginst each other all will be built the same to keep it even i should get the shaft and the strut and prop on today
      • andym
        More Go Than Show Prop Co
        • 2406
        Hope you are keeping the tub held down on a good building board when adding your glass etc. The deck adds alot of strenght to randy's ABS boats and I have had one twist building like you are. Looks good and micro boats are a lot of fun to build and run
        • waynedawg
          • Aug 2008
          • 132
          when i put the glass in i had it held down on my board
          • waynedawg
            • Aug 2008
            • 132
            update
            ok the stuffing tube and liner are in and the prop
            • waynedawg
              • Aug 2008
              • 132
              sorry pics arent to good something not working right with camera
              • Jesse J
                Former scale FE racer
                • Aug 2008
                • 7198
                might try using the macro option, its the flower button usually.
                "Look good doin' it"
                See the fleet
                • waynedawg
                  • Aug 2008
                  • 132
                  ok thanks
                  • Dr. Jet
                    • Sep 2007
                    • 1707
                    That prop looks awfully deep. I would start with the bottom of the strut even with the bottom of the sponsons, and plan on raising it some as you dial it in.
                    You may have to move the prop back to miss the strut, but it looks like you have room for the adjustment.
                    • Joe Friars
                      • Dec 2007
                      • 99
                      Nice hardware. I am giong to install the same Mystery motor/esc combo in my Micro Scat Cat. Are you planning on any cooling fo the ESC? Just curious.
                      Thanks.
                      Joe
                      Joe Friars
                      • waynedawg
                        • Aug 2008
                        • 132
                        no cooling as of yet we are going to chack temps then decide on the cooling. what hardware are you going to use?
                        • Joe Friars
                          • Dec 2007
                          • 99
                          Micro Cat
                          I bought mine used from Taylor, it came with the rudder already installed. Not sure of the make. Randy at BBY made the strut for me. It came with a 540 motor which I ran with six cells. It hopped like mad at first.
                          I am going to install the Mystery combo and run 2s2p lipos about 1800-2000 mah.
                          It has ride pads installed that extend al the way to the back of the hull, apperently to counter the tourqe roll from the 400 Mega motor he ran.
                          Not sure how they will will work with the Mystery.
                          Joe
                          Joe Friars
                          • waynedawg
                            • Aug 2008
                            • 132
                            joe do you have any pics of your cat i would like to see it
                            • Dr. Jet
                              • Sep 2007
                              • 1707
                              I've had a lot of success using that motor in micro hydros, but the cat may need more oomph. I initially ran my MSC with two of those and it did not overly impress me. I switched to bigger, higher Kv motors and it made a huge difference.
