Phil Thomas Stealth 45 Q Sport Build
  • Shooter
    Team Mojo
    • Jun 2009
    • 2558
    Wow! Looks great Mike!
    • Shooter
      Team Mojo
      • Jun 2009
      • 2558
      Btw, that sniper absolutely rips!!!
      • TRUCKPULL
        • 2971
        Mike
        I should have got you to build my twin CAT.
        Your Hydro build only took 32 minutes
        Looks GOOD,- Nice WORK!
        Larry
        • Mike W
          • May 2018
          • 348
          Originally posted by TRUCKPULL
          Mike
          Larry
          You gotta use the fast epoxy!
          Otto RC Marine
          • phil t
            • Feb 2010
            • 168
            The new cowl looks good, have you done a mold of it so you can make more? I may have to get a FE Stealth running.
            Phil Thomas
            email [email protected]
            http://www.philthomashydros.com
            • Mike W
              • May 2018
              • 348
              Not yet but I'll send you one when I do!
              Otto RC Marine
              • Mike W
                • May 2018
                • 348
                Oh forgot to post gotta few Orange Crush decals on her:
                Otto RC Marine
                • ray schrauwen
                  • 9471
                  #23
                  Very nice! How was the windshield done?
                  Nortavlag Bulc
                  • Mike W
                    • May 2018
                    • 348
                    #24
                    I got it third try. Used the masking tape template method then cut from vinyl with scissors. Curves were too severe for a one-piece to conform so I had to cut it up the middle and then hide the imperfect seam with a small 1/8? strip.
                    Otto RC Marine
                    • Mike W
                      • May 2018
                      • 348
                      #25
                      First test runs completed today! It was extremely fast and a bit flighty on the top end, but the water could have been less rough too. I lowered strut, angled fin, and moved CG forward in small steps and saw steady improvement. Someone grabbed an awesome pic!
                      Otto RC Marine
                      • Mike W
                        • May 2018
                        • 348
                        #26
                        Test log slightly rough water but still probably in the 70's. Will get more solid info after nailing my setup. Currently TP4060 1750KV, Y547:
                        Otto RC Marine
                        • Route66
                          • Nov 2023
                          • 7
                          #27
                          Hey Mike, 2 1/2 years sense your post. I’m getting ready to build a Stealth 45 FE, should have the hull tomorrow. Great post/thread/build tips by the way..! Any other input or advice..? I have built & run the Stealth 21, pretty straight forward and runs great… Thanks for the info.
                          • Mike W
                            • May 2018
                            • 348
                            #28
                            No I'd build another exactly the same today. I still like the 1650KV/Y547 for circuit racing. She'll take more and run low 80's but its a bit much for race water. You do want the servo/batts as far forward as they will go to keep the CG as close to the rear of the sponsons as possible so it stays on the water. Fine tune with strut. Install a small triangular chunk of stiff foam equal in height to the batts just ahead of the batts. Just enough to keep them from coming forward and wedging the hull seam open on an impact.
                            Otto RC Marine
                            • Route66
                              • Nov 2023
                              • 7
                              #29
                              Thank you Sir..!
