Strut, stuffing tube question
  • ken webb
    • Oct 2010
    • 69
    How far into the strut should the stuffing tube go?
  • fweasel
    master of some
    • Jul 2016
    • 4286
    It really depends on the design of the strut and the angle the hull meets the strut. If it goes too far, you'll limit or possibly eliminate any angle adjustment. If it doesn't go in at all, it can be a source for leaks or leave the flex cable unsupported. I extend the brass as far as I can, making sure it does not interfere with any drive angle adjustment. I also extend the teflon liner as far as I can, on twin cat setups for example, with long drives. It usually goes past the angle adjustment point, but needs to stop short of the transition from flex to solid stub shaft so that it doesn't cause binding.
    Vac-U-Tug Jr (13mph)
    • ken webb
      • Oct 2010
      • 69
      Thanks. That's what I wanted to know.
