Titan 33 stinger strut height
  • tjj atx
    • Mar 2018
    • 109
    I'm trying to figure out a Titan 33 for P and I am pretty sure my strut is to low. I do not have a flooded stuffing tube set up at this point but have a little bit of adjustment with the speedmaster stinger. Any suggestions on height to center?? I know there are a ton of variables but what would be the lowest I would want it??
  • Jesse J
    scale FE racer: Namba 826
    • Aug 2008
    • 7083
    I make my flood chambers to allow for 1/4” to 5/8”.
    A good place to start would be 1/2” from keel to center of shaft. I was using ~1800kv 4070-90 size motor and 52mm prop.
    Flood tube is all I do on monos now.
    "Look good doin' it"
    See the fleet
    • tjj atx
      • Mar 2018
      • 109
      I'm at about 5/16" right now and I'm gonna try that next weekend. To get the 1/2" I will have to pull the strut off and open up the hole for the stuffing tube. If I'm gonna do that I'll go ahead and install a flood tube, should have done it when I built the boat. I'll make that a project next month, thanks for the help.
      • martin
        • 2887
        On a Pursuit which is a very good 32" & stable deep V the center is 5/16" up from the keel.
        • tjj atx
          • Mar 2018
          • 109
          Ok. I'll set it up where my lowest setting will be at 5/16". Looks like the speedmaster stinger gives you 3/16" adjustment?? That will put my highest option at 1/2". BTW I will be running a 4050 1950kv with a 200amp ZTW and start with an X445 and an 1814.
            • 8012
            My Titan 33 ran the bottom of the stinger 1/4? above the vee and that was too low, the boat would chine walk at speed. I suspect that placing the CL of the shaft at 1/2? might still be too low in race water. On smooth water it may work.
            • Jesse J
              • Aug 2008
              • 7083
              This is a very different hull.
              I am speaking from having set up three titan 33”, two of which I and another club member gave Jay (fluid) a run for his money with!
              See the fleet
              • tjj atx
                • Mar 2018
                • 109
                Titan 33 at 1/2" to center of stuffing from bottom of hull. Jeese, since you have built three titans I'll take your word for it. One more question, should 1/2" to center be my lowest option? I went ahead and started installing the flood tube this afternoon. The flood tube is big enough to give me plenty of vertical movement. I will be re drilling the transom for the new strut location tomorrow. Just want to confirm 1/2" to center should be my lowest position.
                • Jesse J
                  • Aug 2008
                  • 7083
                  I’d go with 1/2” as center, with 1/4” up/dn options. This will allow for prop size and water condition adjustability.
                  See the fleet
                  • tjj atx
                    • Mar 2018
                    • 109
                    Will do. Thanks for the help guys.
                    • tjj atx
                      • Mar 2018
                      • 109
                      I just ran the titan 33 with the flooded tube with the strut at 1/2" to center. Wow what a difference!!! Super stable and the temps where very low with an X445. I will run an X447 this weekend, needs a little more speed. Thanks for the help and flood tubes from now on.
                      • tjj atx
                        • Mar 2018
                        • 109
                        Jeese, what hull is that Malibu?? You sold that boat to Eric with HOTMBC?? He was thinking of selling and told me I would be the first to know. Just curious.
                        • Jesse J
                          • Aug 2008
                          • 7083
                          Travis, that is a heretofore unanswered question.. I got the bare hull from Jim “the Legend” Vaughn.
                          See the fleet
                          • Jesse J
                            • Aug 2008
                            • 7083
                            See the fleet
