I'm trying to figure out a Titan 33 for P and I am pretty sure my strut is to low. I do not have a flooded stuffing tube set up at this point but have a little bit of adjustment with the speedmaster stinger. Any suggestions on height to center?? I know there are a ton of variables but what would be the lowest I would want it??
Titan 33 stinger strut height
I make my flood chambers to allow for 1/4” to 5/8”.
A good place to start would be 1/2” from keel to center of shaft. I was using ~1800kv 4070-90 size motor and 52mm prop.
Flood tube is all I do on monos now."Look good doin' it"
See the fleet -
I'm at about 5/16" right now and I'm gonna try that next weekend. To get the 1/2" I will have to pull the strut off and open up the hole for the stuffing tube. If I'm gonna do that I'll go ahead and install a flood tube, should have done it when I built the boat. I'll make that a project next month, thanks for the help.Comment
Ok. I'll set it up where my lowest setting will be at 5/16". Looks like the speedmaster stinger gives you 3/16" adjustment?? That will put my highest option at 1/2". BTW I will be running a 4050 1950kv with a 200amp ZTW and start with an X445 and an 1814.Comment
My Titan 33 ran the bottom of the stinger 1/4? above the vee and that was too low, the boat would chine walk at speed. I suspect that placing the CL of the shaft at 1/2? might still be too low in race water. On smooth water it may work.
Titan 33 at 1/2" to center of stuffing from bottom of hull. Jeese, since you have built three titans I'll take your word for it. One more question, should 1/2" to center be my lowest option? I went ahead and started installing the flood tube this afternoon. The flood tube is big enough to give me plenty of vertical movement. I will be re drilling the transom for the new strut location tomorrow. Just want to confirm 1/2" to center should be my lowest position.Comment
I’d go with 1/2” as center, with 1/4” up/dn options. This will allow for prop size and water condition adjustability."Look good doin' it"
See the fleetComment
I just ran the titan 33 with the flooded tube with the strut at 1/2" to center. Wow what a difference!!! Super stable and the temps where very low with an X445. I will run an X447 this weekend, needs a little more speed. Thanks for the help and flood tubes from now on.Comment
Travis, that is a heretofore unanswered question.. I got the bare hull from Jim “the Legend” Vaughn."Look good doin' it"
