Black Pearl II Hydro - 2020
  • Shooter
    Team Mojo
    • Jun 2009
    • 2520
    #181
    I wish I could have been there too! Seems everyone is running hot set-ups now. Not sure I can even compete anymore!
    • Namba328
      Factory Team Pilot SPP
      • Jul 2011
      • 1132
      #182
      Originally posted by Shooter
      There's some hop there, but it appears you are still carrying a lot of speed thru the turns. Nothing wrong with that! It shows a little bottom every once in awhile, but stays upright. Looks good.
      Are you using the castle 240 esc? If you can find a way to get the esc temps to stabilize and not continuously rise, then maybe it would be OK? I have the same problem. The cooling on those things is not adequate IMO. Mike Ball did a really nice upgrade. I'm hoping to do it soon.
      Castle xlx with tubing soldered directly to the buss bars. Max temps I'm seeing is 175-180. But what's weird is I'm not getting that when the boat comes in. So idk how accurate the temp data is.
      Tommy Levescy sponsored by: RCJuice.com, Rawspeed, Scorpion Precision Performance, TC Racing, Triton RC, Oxidean Marine and Cencal Hobbies.
      Current Namba 1mile record holder: Pltd sport hydro 1:19:72 P-sport hydro 1:14:31
      • Shooter
        Team Mojo
        • Jun 2009
        • 2520
        #183
        Had a chance to run the new V12 design again last weekend. Not sure if it's in the geometry of the hull or the cowl, but the boat has an amazing ability to hover for a long time without blowing off. At first I thought it was just a fluke, but it repeatedly does it! I tried to slow the video footage down to demonstrate below.
        Typically, hulls like this reach a point and then snap off without even giving you warning, especially at these speeds (70mph). This new design is a blast.....
        • Shooter
          Team Mojo
          • Jun 2009
          • 2520
          #184
          If you watch closely, it looks like it's bleeding all the air out and then settling.
          • TRUCKPULL
            • 2971
            #185
            Looking good Pete.
            • T.S.Davis
              • 6228
              #186
              I'm getting the same kind of data on my little Mamba X in LSH. Comes off the water at 110 or so degrees on the gun but the data log says 195. Maybe internal temps? Nothing seems angry.
              Noisy person
              • T.S.Davis
                • 6228
                #187
                Pete, what version is the boat you cut for me that has the wide innards? I still haven't run it. Probably make Tyler drive it some so we can learn before I wreck the danged thing.
                Noisy person
                • Namba328
                  • Jul 2011
                  • 1132
                  #188
                  It's the one part of the data that's throwing me off. Other than that the rest of the data I'm semi happy with
                  • Shooter
                    Team Mojo
                    • Jun 2009
                    • 2520
                    #189
                    Check the inside of the motor mount rails. I usually put a serial number and version. If not, it could be an imposter! :)
                    • Shooter
                      Team Mojo
                      • Jun 2009
                      • 2520
                      #190
                      Was talking to Terry last night. Tyler's older version hull also has this ability to 'hover' prior to blowing off. Thinking it could be attributable to the leading edge not being blocked by the nose cone (new canopy design). Tyler's doesn't have a nose cone either.
                      Here is the full video of the V12 btw:
                      • TRUCKPULL
                        • 2971
                        #191
                        Pete
                        Your video from post #183
                        Looks like it is dragging the rear-end a little bit.
                        A little bit of Down on the strut. or even down on the rear of the strut for a little Negative angle.(2 degrees)
                        Remember - If you do the above, it will automatically do the statement below.
                        If the turn fin is lifting out of the water on the straight's' angle the rear of the turn up a little,
                        so the hook bits a little instead of running up on the bottom of it. (1 degree at a time)
                        LJ
                        • Shooter
                          Team Mojo
                          • Jun 2009
                          • 2520
                          #192
                          Thanks Larry!
                          BTW, those slo-mo vids were actually taken from THIS video with the 1814 prop:
                          • TRUCKPULL
                            • 2971
                            #193
                            Thanks Larry!
                            https://www.youtube.com/watch?v=Hq1AA891pdI
                            What motor are you running? also is that a 4S2P setup?
                            LJ
                            • TRUCKPULL
                              • 2971
                              #194
                              I run the 1815 prop on mine with a New 1515- 2200kv.
                              4S 2P with 5000's
                              LJ
                              • T.S.Davis
                                • 6228
                                #195
                                Thanks Larry!
                                There's something wrong with that prop.
                                Larry, the tunnel on this is so shallow it always looks like it's dragging. I worried it wouldn't break free when he first brought it out. Not sure you ever saw it but the hull I called the Joule had that problem. Ran like a vacuum cleaner. Pete's breaking free. Just looks weird.
                                Noisy person
