This may help.
When I built my rigger I built the tub and sponsons to the approximate dimensions of the predator.
Then I took the tub and loaded it with the running gear, I then set the sponsons on the build table in a position that gave me the desired CoB or CoG and AoA.
From here I then plotted onto the hull and sponsons the mount points or more accurately the drill holes for the cf booms.
I can appreciate that you are keen make it adjustable as much as I am with my next design / build. my feeling is towards the fixed rear boom and adjustable front boom that is through 2 small booms / supports off the front of the main tub.
It is my belief that the design should be very close to optimum and the limit of adjustment then only needs to be minimal.
For me, I would go with an external front boom adjustment as it is easier.
Always keen to help.
