OK, I'm finally getting around to my rigger build.
I picked up these sponsons:
I have some Carbon Fiber sitting around and am considering using it for this build. I'm also considering creating CF rails much like the Graupner that Diego recently acquired.
Scenario: Rigger will be just shy of 20" in the 50s range, maybe up to 60. I think I have the power system worked out for this, but still crunching the numbers.
First a few questions for the rigger guys: At these speeds, how important is tub design? Should I opt for a sweeping wedge type or something more aggressive? More specifically, I am assuming that at these speeds, aero will be more important. With this in mind, where on the tub should the crest or maximum height be (after which there will be lift created)? Please note that this is an ultralight build and a kevlar type material may be used to skin foam for the tub. Last question is, how much angle should be under the nose? I know that it will not come in contact with the water at all when at speed, so how much lift should be created there which in turn would lift the sponsons out of the water, if any?
So here is my dilemma regarding attaching the sponsons: I have the concern that I may not get the angle just right for the wet ride sections and I may have to adjust. Other than the Xzess adjustable and the Graupner rigger, what other adjustable designs has everyone else seen?
My thought is, if I run a tube through the nose and then run the front boom through it, then that portion could easily move and the back part of the sponson would be supported (and adjustable) using the CF straight edges (rails) to the back of the rigger (much like the Graupner rigger).
Anyone care to weigh in? Meanwhile, I'll get some better pictures of the sponsons and see what I can do about drawings (digital camera is MIA at the moment, LOL).
