Sounds like you have some good batteries, but wouldn't a lower 4200mah (same brand as your 5000) discharge faster and give more rpm at prop. Would 4200 be enough for heat race? What are some good lipo tricks to go faster?
The Black Pearl LSH Spec Hydro 2019
Capacity doesn't affect RPM...just run time. A higher C rating should help to a point.Comment
This is something the car guys do...LiPo batteries seem to perform better when they are warm. When I was racing 1/12th a lot I would just use 1 battery pack and recharge between heats because it got better each successive run. I believe the theory is a warm (Not hot) pack seems to have less internal resistance. HOWEVER...I do not recommend doing either...Any gain you get is extremely small and lost if you do any warm up laps or wreck. Basically on the car side of RC doing that might help the top 1% of drivers out there...but that's about it.Comment
Yup...more capacity = longer time before the voltage curve turns downward.Comment
