Just get the Proboat 2000 (DYNM3831) and move on. They're solid enough and will turn 45mm props on most boats. Good starting point that is.
The Black Pearl LSH Spec Hydro 2019
I've been running the AQ2030's on my LSH since the first UL-1 with relatively no problems and my boat is no slouch:
Couple things I've found that help:
1. As much coolant flow as possible.
2. Water outlet on can should be on the TOP, otherwise you create a huge air bubble hotspot.
3. Water outlet at the highest point (back of the motor).
4. Motor radially mounted such that wires are at the bottom of can (heat rises, keep it away from them).
5. Heat soak fins like the ones on my post a few above. These work great for the end of the race.Comment
https://www.ebay.com/itm/223479932325?ul_noapp=trueSee the danger. THEN DO IT ANYWAY!!!
http://forums.offshoreelectrics.com/...hp?albumid=320Comment
Where do you find those fins?
LarryPast NAMBA- P Mono -1 Mile Race Record holder
Bump & Grind Racing Props -We Like Em Smooth & WetComment
Question: Do you notice a difference in flow with the 90 degree inlet/outlets? I was wanting to put some on mine but a local mentioned it might adversely affect the water flow in and out of the jacket.Comment
Plus he can drive.. but the 1500s are still best motor out.. though that will change now that not available.. but I have been running mine now for 4 yearsComment
Tommy Levescy sponsored by: RCJuice.com, Rawspeed, Scorpion Precision Performance, TC Racing, Triton RC, Oxidean Marine and Cencal Hobbies.
Current Namba 1mile record holder: Pltd sport hydro 1:19:72 P-sport hydro 1:14:31Comment
When I posted the link he still had some.
He sold two the next day, & the last one the day after.
I was hoping that you managed to score one.
Unlucky.
Aren't they replaced by the Dynamite 1500kv motors?
They are the motors that we use at our club here in Australia, now that the original Proboat motors are discontinued.
These ones.
https://www.amainhobbies.com/dynamit...nm3835/p234183
Not sure if they are as sturdy as the originals but mine are still going strong.See the danger. THEN DO IT ANYWAY!!!
Unlucky.
These ones.
Not sure if they are as sturdy as the originals but mine are still going strong.Tommy Levescy sponsored by: RCJuice.com, Rawspeed, Scorpion Precision Performance, TC Racing, Triton RC, Oxidean Marine and Cencal Hobbies.
