Oval Master Refurb
  • Jimmy Sterling
    • Apr 2008
    • 393
    #31
    Did you ever run a 440 3 blade ? How hot was the motor running the 437 ?
    I was plannning on running it or an M445
    Come to the FASST side
    • Jimmy Sterling
      • Apr 2008
      • 393
      #32
      Latest pics,
      Finished colour, just waiting to get some decals to spray the clear over (take about a week)
      All hardware polished
      This forum is getting reallllly slow, it took me 5 minutes to load that last post
      • tylerm
        • Nov 2007
        • 310
        #33
        Hardware looks really good dude, how did you get that colour?
        • Jimmy Sterling
          • Apr 2008
          • 393
          #34
          Thanks, When you say colour are you referring to the Green or the finish on the hardware
          • tylerm
            • Nov 2007
            • 310
            #35
            The finish on the hardware
            • Jimmy Sterling
              • Apr 2008
              • 393
              #36
              Alot of hard work and time, probaly took me a solid 1 hour of polishing to get it like that. I have a polishing bit setup on dads drill press and it works great, polished up just about anything
              • Jimmy Sterling
                • Apr 2008
                • 393
                #37
                More pictures
                As I filled all of the old holes for water cooling etc, I have relocated them and drilled new ones. I decided to have both my water pickup and outlet on the transom of the boat - I am actually using an octura inlet as an outlet (polished) and I mounted the antenna as high as I could on the side of the hull.
                I have only mounted the 9XL in the boat for mockup purposes to see where the best spot to mount the speedy is as I plan to run a PB motor
                I am also tossing about whether or not I should paint the TF mounts and the Solinger mount the same colour as the hull.
                Jimmy
                • calcagno45
                  • Mar 2008
                  • 1006
                  #38
                  nah, don't paint the mounts! leave them natural/polished!!
                  Looks good tho!!!
                  Is that a safety disconnect loop on the front by the foam?
                  • Jimmy Sterling
                    • Apr 2008
                    • 393
                    #39
                    I'm only painting the TF mounts and yes that is a safety loop. Our club is affiliated with the AMPBA (Australian Model Power Boat Accosiation) and its a rule that all boats have a safety loop if they want too race.
                    • Jimmy Sterling
                      • Apr 2008
                      • 393
                      #40
                      Funnily enough the Octura inlet works better as an outlet as it fires the water upwards instead of straight overboard - should be easier to see when the boat is running
                      • Jimmy Sterling
                        • Apr 2008
                        • 393
                        #41
                        Latest pictures
                        Now waiting on decals for clear coat
                        • jwt
                          jwt
                          • Nov 2007
                          • 59
                          #42
                          Jimmy
                          you have got a green t/fin bracket and a blue washer on the outside of it,,
                          that doesnt work ??
                          tms
                          • Jimmy Sterling
                            • Apr 2008
                            • 393
                            #43
                            that doesnt work ??
                            Yeah I know, I'm working tommorow and I plan to pick some green ones up
                            I also want make some headers for the lid with some left over large diameter brass tubing I found a the bottom of the draw, should help it go faster
                            Jimmy
                            • Scott T
                              • Oct 2007
                              • 590
                              #44
                              Originally posted by jwt
                              Jimmy
                              that doesnt work ??
                              tms
                              Uh Oh, the King of Bling has spoken!
                              Looking good Jim, will it be ready to test on the 14th?
                              Scott Tapsall
                              Pine Rivers Model Powerboat Club - Facebook Page
                              My Gallery
                              • Jimmy Sterling
                                • Apr 2008
                                • 393
                                #45
                                As for the 14th, I'll take mine if you take yours
