Good point. I have found when going from medium to really fast boats, that I need to beef up the rudder linkage. Instead of 1/6" piano wire, I now use .078" piano wire, the next size up. High torque servos and metal servo horns. Get the heavy duty dubros and like the man said, no slop.
head of the river cat hull thread
Thanks Jesse, I don't think there is a direct simple answer.I should be alright with the space to be able to move the batteries there is plenty. As far as the bilge I will install some carbon fiber in the sponsons to try to keep the batteries dry as the sponson battery mounting will give me the most range movement. Thanks for the help and good luck with the intruder I'll be watching the build.Comment
AH HA, that was the next question I am wanting to run it with the pull-pull set -up with 2 linkage rods. I am thinking this should be the optimal set- up for having no slop(but I could be wrong) any suggestions on a servo I know it will have to be low profile and with the inline rudder torque will probrably be an issue also right?Comment
this maybe just preference but i like high torque servos but not high speed, yes the dubro heavy duty quick links with 4/40 rod work really well
have ran these hulls mainly with 6xl and 7xl have had speeds over 60 mph but they are barely hanging on at those speeds a 7xl with a 440/3 gives constant 55mph with good temps after 3 min
have run 4s1p and 4s2p, just remember when setting up c.o.g to measure from back of sponsons not transom on this hull
scottComment
scottComment
push pulls can work well if they fit just not sure of the low profile servos durability, mine works well with a lay down servo i have it setup so it pulls the rod when turning rightComment
yeah I thought it would be a bit tricky to fit the servo standing up I just think the double rods look like the real cats ,oh well just a thought but thanks alot for the help guys I'll keep you posted on the build not sure how long that will be though. I'm waiting on Steve's hardware to return to stock, kinda set on the inline cat hardware but don,t know how long I can wait on it hahaComment
That is a sweet looking water jacket and motor mount. Where did you get them?
thanks again guys this is what I have so far from out of the box to now.This is the motor placement that I figued the batteries could easily correct if its not perfect I think its pretty close though. Oh, and thanks tunda but I think I'll wait for the OSE set-up with the .150 flexMini Cat Racing USA
The low profile servos are made to mount in wings of airplanes for aileron control. Not sure of their strength. Read the specs on them and decide from there.
Mini Cat Racing USA
AH HA, that was the next question I am wanting to run it with the pull-pull set -up with 2 linkage rods. I am thinking this should be the optimal set- up for having no slop(but I could be wrong) any suggestions on a servo I know it will have to be low profile and with the inline rudder torque will probrably be an issue also right?Last edited by bonewar; 07-29-2009, 05:47 AM.SIMRAD MARITIMO TWIN 1512 NEU'S , M12 MARITIMO SINGLE 1527 NEU , SV27 1509 NEU , SV27 NITRO O.S. 18CV-R 3.0cc WATER COOLED RACE ENGINE.Comment
Just received my white cat from HOTR yesterday, I'll be using my medusa 3680 2000kv along with the 180amp marine turnigy esc. I got the cat strut/rudder from HOTR also but have to change over the 4mm bushing to the 3/16 thanks to Peter Z's work. But was wondering if anyone is adding some fiberglass or plywood to the rudder mount area, it seems a bit thin there
Ken
BIGDG357, Mate i 'm running a twin MARITIMO, the servo i use is a futaba digital (s9551) , I have it set up in the hull standing up with wire run throw plastic tube to the rudder( pull ,pull). The servo is very strong and i have not had any problems with driving the hull at almost full throttle around a corner. The servo is a low profile type and will fit under your hatch standing up. Using this servo there is no rudder torque at all. The dimension (40mm L-20mm W-25mm H) , TORQUE @ 6.0V=8.8KG. The only bad point is the cost. Anyway just an option. BONEWARComment
Servo
I used metal linkages to connect to the servo
(local hobby shop) , then run metal cable throw a plastic tube throw the back of the hull to the rudder. In the back of my hull there is styrene for flotation which made it very easy to run the plastic tubes . The styrene helps hold the plastic tubes in place. Also the linkages come with a threaded piece so that you can fine tune the cables so that the servo won't bind. I soldered the wire cable to the connectors (very strong ) . The servo has plenty of torque for your hull . here are a couple of pics for you to see what I'm talking about. BONEWARSIMRAD MARITIMO TWIN 1512 NEU'S , M12 MARITIMO SINGLE 1527 NEU , SV27 1509 NEU , SV27 NITRO O.S. 18CV-R 3.0cc WATER COOLED RACE ENGINE.Comment
.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8sComment
