HPR 115(Average White Boat)
  • Bp9145
    • Jan 2016
    • 1466
    #91
    That's some nice work Shawn. The paint job is so simple, clean of clutter and yet so elegant especially with the stripe combo with the fine little details in it. . . .just love it. . . .very nice indeed. I can't wait to see it zip on the water.
      • 7651
      #92
      Thanks guys, it’s so nice to get it this far and have it turn out ‘by my own hand’.
      Thanks for the praise,
      • fweasel
        master of some
        • Jul 2016
        • 4311
        #93
        You really banged this one out quickly, without cutting corners. Your experience shows. It must be exciting to know its going to hit the water soon!
        And I agree with Brian, your layout of the graphics is dead nuts on. Clean and simple.
        Vac-U-Tug Jr (13mph)
        • CraigP
          • May 2017
          • 1464
          #94
          It’s a great build Shawn! That thing is going to look and sound so good out on the water, I can hear it now!
            • 7651
            #95
            Yes, yes it shall! So happy to be at this point already. So the LMT’s are in and while there I thought I’d share the tricks that make install and removal easy on me. Perhaps you guys can put it to use.
            9036D09E-38FA-4A93-91B2-26DC347E1494.jpgF0CC104B-A03D-42B4-BA04-F0FB112D6855.jpg9AD5DEF5-C236-4C64-BA93-3C90C5140185.jpg
            I fashioned a hex bit onto a .130 flex which goes into my tool kit nut driver. After much futzing and dropping of screws I came up with the loop in the brass wire which gets used as a guide for the screw/hex. Works like a charm!
            • Beaux
              • Dec 2015
              • 550
              #96
              Cool tool.
                • 7651
                #97
                I have ESC’s wired, programmed and installed. ESC cover plates installed. Added a foam bed on sponson floor by ESC’s for batteries to sit on.
                Servo, hydraulics, and cables and cable clamps(courtesy of Kent @cfparts) installed. I had changed servos as I decided to run HV radio system in this one. I’m just going to try it out and see if range increases, hasn’t been a problem but I do know my limitations on the lake.
                I am working on the wiring for the Rx and data tower but figured I’d show off what takes the place of the logger and still holds the Rx battery.
                  • 7651
                  #98
                  And it’s alive!!! Swordy’s seem to be sync’d up well. But one doesn’t wanna beep a cell count. I’ll reprogram and see.
                  • dmitry100
                    • Mar 2015
                    • 1264
                    #99
                    I'll just leave this here... I don't think I would ever be able to unscrew anything without this flexable screwdriver: https://www.amazon.com/ORIA-Screwdri...ewdriver&psc=1
                      • 7651
                      #100
                      That’s a nice setup Dmitry. I don’t know if it would get the bottom screws though. In my instance anyway. But it sure looks like a handy one.
                        • 7651
                        #101
                        So on the ‘last finishing touches’ front, I am so impressed with myself on this one.
                        On these 115’s the hatch fits loose, real loose! So after measuring I decided that a great option would be foam tape stuck to the outside edge of the hatch. So after much searching I found a single roll of 1/16” sticky one side tape on eBay. I installed this morning and now the hatch fits nice and snug. This should be my seal
                        • fweasel
                          master of some
                          • Jul 2016
                          • 4311
                          #102
                          Wow, you weren't kidding. That looks like a hood gap on a car! Looks like that tape was a perfect fit.
                            • 7651
                            #103
                            I know right. I’ve never ran across it before. But it’s like it was meant for this. And it’s awesome! Love it when it works out.
                            • dmitry100
                              • Mar 2015
                              • 1264
                              #104
                              Did you use any extra adhesive for the foam? I'd imagine it would eventually start coming off after getting wet several times
                                • 7651
                                #105
                                Dmitry I think it should be good as the foam tape is 3M for automotive use.
