My boat look like a skipping rock on the water. Please help!
  • BCRacer
    • Jun 2014
    • 5
    Hey,
    I bought the Jet Sprint by Mickie Beez (http://www.offshoreelectrics.com/pro...od=mb-hull-610) off this site and built it as my first ever build. I have had other boats in the past but I thought it would be fun to build something that I could take on the river and now have to worry about tearing up my prop and let my nephew drive like a maniac. The build went fine enough but whenever I put it on the water it just skips. The jet will prime and then shoot it out of the water and then it will hit the water again and repeat. I just can't get it to run smooth no matter what I do. I run 2x8000mah 2s lipo's in series and I have tried them in the back of the boat, the front of the boat and every place in between but I still can't get it to run smooth to get any speed out of it.
    Please help me figure out what I am doing wrong. Here is a pic of the inside of my hull, 2000kv leopard motor with a 180amp esc bought from offshore electrics.
  • boredom.is.me
    • Jun 2009
    • 595
    Is the thrust angle level with the hull? Do you have any video?
    • BCRacer
      • Jun 2014
      • 5
      I have tried level and up and down as it is adjustable. Here is an older video but it is still the same ongoing problem.
        • 7990
        Why not ask the designer of the boat? Mickieb49
        • Tails Up
          • May 2016
          • 51
          Just a WAG,maybe you need to slowly apply throttle on take-off. Perhaps a soft start on the ESC.
          • BCRacer
            • Jun 2014
            • 5
            I have tried slowly applying the throttle. Didn't make any difference
