New person to hobby needs help
  • Rick sroka
    • Nov 2015
    • 5
    hello to all and thanks for read this .New to the sport . But a long time fan !!!
    I looking for a little help on getting a boat hull picked out and made . It;s r/c but not.I going to have a raspberry pi2 (very small computer) control the boat . I am looking at the jet chopper 30 as a hull but the maker has not gotten back to me, now i am second guessing myself . i figure a *!**deep v hull would be my second choice .the biggest lake i would use it in would be lake Winnebago in fond du lac wi *!**. Not huge wave like on the ocean. *!** just need help choosing a hull and who can build it
  • eboat
    • Aug 2007
    • 693
    I have a raspberry I am using for a model train project
    Building a working clam shovel and using the computer to run it
    My raspberry runs off of wifi
    Do you think you will be able to run a boat from shore that way with out getting out of range or is this a computer on board programed to go out and back to the same spot project ?
    • Rick sroka
      • Nov 2015
      • 5
      I going to program a return to user by the gps unit
      • Rick sroka
        • Nov 2015
        • 5
        Can some one help me?
        • eboat
          • Aug 2007
          • 693
          Maybe a few more questions you need to answer first
          1 How big of a box is your control system going to have to live in and sealed up to be water proof including a battery to run it on
          2 How long will it be out driving around on its own ?
          3 How fast will it be going ?
          4 Scale looking boat ?
          5 How much $$ are you willing to spend on just the boat hull and hardware , electric motor , esc and batteries (lipo?)
          • ray schrauwen
            • 9472
            Cool project! I should get a raspberry pi, they are really cool to tinker with.
            Nortavlag Bulc
            • Rick sroka
              • Nov 2015
              • 5
              the computer is 3 and half inches long 2 half width and 1 inch deep. waiting for the battery to show up. 5v
              2 How long will it be out driving around on its own ? 45 mins
              3 How fast will it be going ? not fast
              4 Scale looking boat ? nope , what ever gets the job done
              5 How much $$ are you willing to spend on just the boat hull and hardware , electric motor , esc and batteries (lipo?) what ever I need ...
              thanks
              • eboat
                • Aug 2007
                • 693
                I would lean more towards a cat type of boat
                I think it would be harder to tip over and get into trouble if a wave came along you were not prepared for
                They have a bigger hatch most times than a mono hull boat that would make things easier to work on getting all your parts in
                Is your boat going to have reverse ??
                Not all esc s have reverse
                Not sure how a flex cable drive shaft would like turning the wrong way either so if there is a lot of backing up you might need to go with a solid shaft
                Would a hull like this one be big enough ??
                http://www.offshoreelectrics.com/pro...cat=Boat+Hulls
                I have this one Mean Machine but I do not think there is enough room in it
                http://www.offshoreelectrics.com/pro...prod=Aero-MM-2
                This one is bigger also
                http://www.offshoreelectrics.com/pro...prod=aero-1127
                • Rick sroka
                  • Nov 2015
                  • 5
                  Thanks this helps , looking at this one Delta Force DF45 MK-ll Boat Hull
