Mini Rivercat redo
the mount looks great, but I'm thinking it isn't gonna work well on my mono. thats the kintec one right?
the adjustment screws down the bottom become so obstructed when mounted on slants, you would have a really hard time getting an allen key in there.
may have to rethink my plan....There's a hole at the center of earth where the rest of the world sinks but i stand still...Comment
the mount looks great, but I'm thinking it isn't gonna work well on my mono. thats the kintec one right?the adjustment screws down the bottom become so obstructed when mounted on slants, you would have a really hard time getting an allen key in there.may have to rethink my plan....Attached Files"There's nothing else I really want to do other than get up and build boats." - Mike FioreComment
32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) wasComment
Why would you need to get at the bottom ones anyway? The motor will go in and out for maintenance just using the top ones at the back and the ones into the front endbell, just set it to the angle you want before gluing it in.
If you want to alter the angle for some reason once it is built, you will have to rip out and redo the stuffing tube anyway so cutting down an allen key would be the least of my worries.Paul Upton-Taylor, Greased Weasel Racing.Comment
Paul, it would probably be never, but if I ever changed a motor to a different length or something, it would be nice it they were relatively easy to access
Sent from my iPad using TapatalkThere's a hole at the center of earth where the rest of the world sinks but i stand still...Comment
I peeled at 1 hr and came out good ! I think it helped the edges to settle a little more too."Any intelligent fool can make things bigger and more complex... It takes a touch of genius - and a lot of courage to move in the opposite direction."
--Albert EinsteinComment
Just ran across this thread, nice work!NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:http://forums.offshoreelectrics.com/...est!&highlight=
