1st mono build 29 inch
  • tlandauer
    • 5660
    #76
    Originally posted by okieman98
    [ATTACH=CONFIG]124049[/ATTACH]
    hope it looks ok for my first time, seemed to seal good. nut might have to order some more carbon fiber to Finnish inside hull. but tell the truth enjoying the build and working with my hands again
    Looks Great, that transom is bullet proof now!
    • okieman98
      • Jan 2014
      • 229
      #77
      fix en to pour epoxy in the bow tip should i but some of the scrap pieces of fiber glass are cf in there before filling it up. i have both
      1 motley crew- under construction 2x shock wave 26-2 x surge crushers - 1 30' mono
      • olwarbirds
        Magic Smoke Wizard
        • Oct 2012
        • 1136
        #78
        either one or both is not a problem...your not going to put that much epoxy in there, just enough to fill the tip.... DJ
        • okieman98
          • Jan 2014
          • 229
          #79
          ok got it thanks
          • okieman98
            • Jan 2014
            • 229
            #80
            ok fulled my nose (bow ) with epoxy tonight, used the z poxy the only thing i dont like about it is it does not cure clear and does not show carbon fiber as good as what came with my kit. ok what i did on the bow what took left over scraps of cf pulled it into many stands, mixed it with the first batch of resin, pushed them into place with a wooden mixing stick then added the second cup on top of that, used some cup found at wally world turnd out they where hard plastic and worked very well mixing without melting. 100_2267.jpg100_2268.jpg
            wife not liking me working on the kitchen table. but o well at least i have a peace of plywood down so no mess on table. told her to build me a shop and i will move everything out there along with my beer box but dont think she is going for the shop.
            • okieman98
              • Jan 2014
              • 229
              #81
              ok got the inside laid in to night still wet but it looks like it will do good
              • tlandauer
                • 5660
                #82
                Hmmm... sending my boats to you...
                • okieman98
                  • Jan 2014
                  • 229
                  #83
                  lol need to get a little better yet, wish there where clubs around me, it 100 miles to the nearest one. can find anyone close into boat just a flying club.
                  • olwarbirds
                    Magic Smoke Wizard
                    • Oct 2012
                    • 1136
                    #84
                    Looks really good, specially it being your first attempt at this...alot of us have same prob with lack of clubs, you have to do what I been working on and that is getting a club going in your area..takes awhile but our club is building... DJ
                    • tlandauer
                      • 5660
                      #85
                      ok fulled my nose (bow ) with epoxy tonight, used the z poxy the only thing i dont like about it is it does not cure clear and does not show carbon fiber as good as what came with my kit. ok what i did on the bow what took left over scraps of cf pulled it into many stands, mixed it with the first batch of resin, pushed them into place with a wooden mixing stick then added the second cup on top of that, used some cup found at wally world turnd out they where hard plastic and worked very well mixing without melting. [ATTACH=CONFIG]124084[/ATTACH][ATTACH=CONFIG]124085[/ATTACH]
                      Man, that bow of you boat is as sharp/hard as a harpoon! As for working on dinning table, i have the same issue, i don't have a workshop and the garage is full of my toys, I face more "danger" if I have to reorganize my garage for work space.
                      • okieman98
                        • Jan 2014
                        • 229
                        #86
                        thought this would help on hardware
                        • tlandauer
                          • 5660
                          #87
                          To give you a perspective , here is the stinger and rudder on my 32" lizard Xtreme:
                          Your transom is not that tall, select wisely, also you need to consider trim tabs, real estate is going to be a bit tight.
                          • okieman98
                            • Jan 2014
                            • 229
                            #88
                            thanks that gives me a good idea what everything is going to look like back there, looks good and clean. i see u have dual water pickup. are u running one on esc and the other on motor to keep heat down
                            • tlandauer
                              • 5660
                              #89
                              Yes, two separate loops. In retrospect, it is not necessary the way I run my boats, I was just trying to be fancy, and the rudder is bigger , also longer which i had to cut short a bit, remember, anything big in the back just increases drag, keep it simple is the best policy.
                              • okieman98
                                • Jan 2014
                                • 229
                                #90
                                well waiting to order more parts, not much $$$$ left after black Friday shopping, i have six kids and 3 grand kids might have to wait till after xmas to get more.
