Mean Machine Build
  • 00garyc
    • 71
    Mean Machine Build
    I need some advice got a MM nitro hull cheap I converted to FE. used all stock MM hardware and SV motor esc. runs ok but gets hot. I have a hydra 120 and 8xl motor any body have suggestions? also the boat wont turn left 1/2 speed or better tried numerous servos the rudder is exactly across from the prop should I kick it back a couple of inches? Thanks
  • ReddyWatts
    • 1711
    Have you raised the bottom of the strut up 1/4 to 3/16 above the bottom of the hull?
    Which prop and voltage are you using?
    ReddyWatts fleet photo
    • Jeff Wohlt
      • Jan 2008
      • 2716
      That is a big hull for that motor. I have the same hull but a FE layup and is lighter. You really need to step up to a 10-12 Xl and 16-18 cells. Easy on your gear and will have moroe torque to spin a bigger prop.
      I am trying a 9XL with 14 cells and a 640 prop.
      Strut level with sponson bottom. CG of about 25-30% to keep her light.
      www.rcraceboat.com
      [email protected]
      • 00garyc
        • 71
        MM Build
        Reddy, I have moved my strut even notched it to give me more angle it rides nice the front is up running approx 4" on the rear I am using 2s lipos with a x445/2 blade seems to be the best I think I will set my rudder back 4" get it away from the prop. do you have any advice on the 8xl with hydra 120? thanks
        • 00garyc
          • 71
          thanks Jeff anything would be better than the stock SV setup for this hull
          • ReddyWatts
            • 1711
            8XL on 4s lipo and a hydra 120;
            These props will get the mean machine into the 40's safely. You can try larger props after a setup with one of these. They are all under 100 amps.
            X537/3
            X440
            X637
            • 00garyc
              • 71
              thanks reddy I should have it ready to go by next weekend as long as steve gets my order out early(HA HA) let you know how I make out
