I need some advice got a MM nitro hull cheap I converted to FE. used all stock MM hardware and SV motor esc. runs ok but gets hot. I have a hydra 120 and 8xl motor any body have suggestions? also the boat wont turn left 1/2 speed or better tried numerous servos the rudder is exactly across from the prop should I kick it back a couple of inches? Thanks
Mean Machine Build
Have you raised the bottom of the strut up 1/4 to 3/16 above the bottom of the hull?
Which prop and voltage are you using?Last edited by ReddyWatts; 08-10-2008, 12:35 PM.ReddyWatts fleet photo
Mean Machine - Feigao 540 14XL, 8s, 100 amp HV esc, X537/3 -
That is a big hull for that motor. I have the same hull but a FE layup and is lighter. You really need to step up to a 10-12 Xl and 16-18 cells. Easy on your gear and will have moroe torque to spin a bigger prop.
I am trying a 9XL with 14 cells and a 640 prop.
Strut level with sponson bottom. CG of about 25-30% to keep her light.Comment
MM Build
Reddy, I have moved my strut even notched it to give me more angle it rides nice the front is up running approx 4" on the rear I am using 2s lipos with a x445/2 blade seems to be the best I think I will set my rudder back 4" get it away from the prop. do you have any advice on the 8xl with hydra 120? thanksComment
8XL on 4s lipo and a hydra 120;
These props will get the mean machine into the 40's safely. You can try larger props after a setup with one of these. They are all under 100 amps.
X537/3
X440
X637Last edited by ReddyWatts; 08-10-2008, 03:52 PM.ReddyWatts fleet photo
Mean Machine - Feigao 540 14XL, 8s, 100 amp HV esc, X537/3Comment
