Avanti's NEW micro Gator air boat
  • Avanti
    • Nov 2007
    • 1280
    #31
    2nd video
    • Dr. Jet
      • Sep 2007
      • 1707
      #32
      How to make a pusher prop:
      1. Hold a tractor prop in your right hand with the convex side (the front) facing up.
      2. Using your left hand, turn the propeller over.
      3. Install the newly created pusher propeller on your motor shaft, being careful not to allow it to return to "tractor" mode.
      A nation of sheep breeds a government of wolves
      • obrien
        • Nov 2007
        • 1264
        #33
        looks good!
        • ace028
          • Aug 2007
          • 952
          #34
          Would just reversing the motor instead of mounting it forward work? Could you move the weight to the rear to help the nose from dipping down? Looks like a lot of fun! Great job!
          Twin power =
          • Avanti
            • Nov 2007
            • 1280
            #35
            I thought that would work, but the guy at the LHS had me second guessing myself.
            • highndry
              • Nov 2007
              • 664
              #36
              Looks good. You may have to add wings!
              Boats don't win races, drivers do.
              • highndry
                • Nov 2007
                • 664
                #37
                Got mine framed up today
                • Avanti
                  • Nov 2007
                  • 1280
                  #38
                  I just got done flipping the motor mount around for a pusher. I am working on the leaks now. I will be really mad if I kill more radio equipment. not sure if I will have enough day light for a second run or not. Hopefully with the motor flipped I will be able to use all available power.
                  • highndry
                    • Nov 2007
                    • 664
                    #39
                    John,
                    you have pm
                    • Avanti
                      • Nov 2007
                      • 1280
                      #40
                      Wow I just tested it here at the house. it will zip across almost anything. It ran right through the grass, right across brick pavers, and then I took it in the house and ran it on the tile and wood floor. This little outrunner could have easily pushed a bigger boat.
                      • kck741
                        • Aug 2007
                        • 265
                        #41
                        wow thats awsome it didnt damage the finish on the paint did it
                        S.S.R.C-Southern Style Radio Control
                        • Avanti
                          • Nov 2007
                          • 1280
                          #42
                          some scratches from the bricks, but it's on the bottom. I can alway throw some more cherry valspar on
                          • Avanti
                            • Nov 2007
                            • 1280
                            #43
                            next I am building a cage for the prop so I can run thru grass and not damage the prop.
                            • Dr. Jet
                              • Sep 2007
                              • 1707
                              #44
                              We used to put motorcycle number backing tape on the bottom of our gliders to keep them from getting scuffed up. The car guys have something similar (although heavier) and I think they call it chassis tape. ( ) This stuff is clear and bullet proof, in addition to being slick. You could put this on the bottom of your hull and race in a parking lot. Even better, race in a poorly graded parking lot after a heavy rainfall.
                              • Avanti
                                • Nov 2007
                                • 1280
                                #45
                                bottom tape not a bad idea doc, but I'll just let it go for now.
                                I just got done running it again, the wind played h3ll with it. my rudder needs some work as it loosened up a bit. once I build the birdcage the rudder ca be pined top and bottom. I am also going to add a couple strakes
