Experimental Genesis 'M' hull.
    • 9488
    #61
    Very cool man!
    • tlandauer
      • 5666
      #62
      I enjoyed watching your video, congrats and please post more, can`t wait!!!
      On a sidenote, if you think you are leaning towards being an idiot, then guys like me really dont stand a chance.... Something I was afraid of thinking.....
      Anyway,
      Cheers!
      • 785boats
        Wet Track Racing
        • Nov 2008
        • 3169
        #63
        Thanks guys.
        Now that's funny. But you shouldn't be so hard on yourself.
        Next weekend is a practice day at our race lake, so we'll get some videos & a GPS reading hopefully.
        Like I said before, I rushed things a bit to get this baby on the water & just used what I had lying around.
        The linkages & rods I used for the rudders were way undersize & had too much flex & slop. So I've now bought some 3mm rods to match some 3mm threaded ball linkages that I had, straightened out the geometry a bit, & added a tie rod between the blades. Much more solid & precise with no slop whatsoever. I'll be much more confident in the turns now.
        Here's the new set up.
        • dasboata
          • Dec 2010
          • 3152
          #64
          Great job !
          • Monica Smith
            • May 2013
            • 162
            #65
            Oh my god! I can't believe it, you sucessed, Paul!
            Congratulations!!
            When we are no longer able to change a situation, we are challenged to change ourselves.
            Email: [email protected]
            • Doby
              KANADA RULES!
              • 7280
              #66
              Congratulations!!
              Well Monica, you now have TFL's next new "Cat" for production next year..It can be set up with single, double or triple motors!!!
              Grand River Marine Modellers
              • 785boats
                Wet Track Racing
                • Nov 2008
                • 3169
                #67
                Thanks for that guys.
                When I can get it around the corners at full noise, then I'll consider it a complete success.
                • Fella1340
                  • May 2013
                  • 1035
                  #68
                  Excellent job, very inspiring to watch something like that come together. It's great to see something like this move from the idea stage to a reality, that alone is a huge success imo. I was thrilled to see it run so well and I hope to see more of the boat soon!
                  • 785boats
                    Wet Track Racing
                    • Nov 2008
                    • 3169
                    #69
                    Thanks for that Fella.
                    I must admit, there is an inherent sense of satisfaction with this sort of project. Within our club I'm known to make some weird models. Here's one you may appreciate. Conceived & drawn up from an artists impression in a Navy Magazine. Im not sure if the Navy even built it in the end.
                    Still a lot of things to try out on this one yet. The one playing on my mind the most is whether or not to fill in the inverted V shape of the centre sponson.
                    Still have to try the outside props spinning the other way yet. That will happen this weekend.
                    Paul.
                    • flraptor07
                      • Aug 2013
                      • 2451
                      #70
                      Paul.
                      Paul,
                      I would run that boat a lot more before I decided to fill in that center sponson. If I did fill it in, I would make it a slight V in the opposite direction. But it looks like it runs pretty nice the way it is, you should try to figure out a way to fil it temporary just to see how it works then you could take it out if it doesn't work.
                      • 785boats
                        Wet Track Racing
                        • Nov 2008
                        • 3169
                        #71
                        Are you some sort of mind reader or something? That's exactly what I intend to do. If I do it.
                        Just lay down a drizzle of Eco expanding foam & then sand to shape & glue a thin 1/32" piece of ply or polystyrene sheet on it. Easy to rip out & dissolved with acetone to clean it up.
                        But yes. There are other things to play around with yet, & that will be most probably the last one. If at all. 'Cos it just looks so cool & menacing under that hull.
                        Thanks for your thoughts.
                        Paul.
                        • ray schrauwen
                          • 9471
                          #72
                          Very Impressive thread and project, I'm inspired!! I thought twins were cool, triples and Quads, whoa..!
                          Which way are the props spinning viewed from behind the boat? I didn't see you post that info but, I might have missed it too.
                          I really need to try and build something like this, at least a twin.
                          Nortavlag Bulc
                          • ray schrauwen
                            • 9471
                            #73
                            Just found it, cool. What size are the props? I'll keep reading and maybe I'll find that too...
                            Nortavlag Bulc
                            • 785boats
                              Wet Track Racing
                              • Nov 2008
                              • 3169
                              #74
                              Hi Ray.
                              Yes, It's been great fun, this one.
                              Yep. As you've found, Inward at the tops & the centre one normal.
                              I'll be reversing the outside ones this weekend to see what happens.
                              They are CNC 4614/3 blade props.
                              • rearwheelin
                                • 1941
                                #75
                                --Albert Einstein
