Epoxy On The Hatch!!
Hi guys,
I decided to work on the mini Cat today and have Epoxied the Styrofoam form of the shape I chose. It took two coats with a nib sanding between the two and no I did not thin with alcohol or anything else!! I just used straight old 30 min epoxy and mixed about 1/2 of it and painted it on with a flux brush, it worked great, the second coat flowed out real well, and I cut the underside out further up closer to the front for more battery clearance, I needed it for a 3 cell, I was toying with the idea of pouring some lacquer thinner into the cavity and melting the foam out, but so far have not tried that. but here are some pictures of what I have been doing.
The third picture is so you can compair how much of the hatch I cut out on the under sde.
Hi guys,
