29" Skunk Works Vee
  • westbeach
    OSE Rocks!
    • 951
    Skunk Works
    Can you guys tell me how well this hull runs in comparison to the Delta Force hulls. They look identical and all. And what is Scotty @ Skunk Works charging for one of this hulls?
    Thanks
    Neal
    HPR115 x2 ,Dark Horse Shovel, Delta Force CyberStorm, Delta Force Sniper 23-RTR:
    • Skunk Works
      • 183
      Scotty here!
      Been on the road.
      Chop, looks great! I love that hardware package. Do have setups in the shop. Out of the 29 hulls at the moment. Quality is good, strong. The hardware is what makes this hull.
      Cooling: Check the length on you tubes, want them to be short as possible. that may help.
      Stay in front and don't get sprayed!
      • ED66677
        • 1300
        this hull handles great no matter the weather!
        Emmanuel
        • westbeach
          OSE Rocks!
          • 951
          So does the Skunk Works Vee come with hardware? What does the kit cost?
          • Eodman
            • Sep 2007
            • 1253
            Morning guys, One thing I noticed on my twin cat build - When I installed the fittings on the motor for cooling I got a little over zealous when I tightened the fittings down! I think they were to close to the motor causing the resistance. I backed them out and the flow improved greatly! Had to change the o-rings but it did help water flow!
            We did it with a Bang!
            Cats Are Where It's At!
            • Chop
              • Nov 2007
              • 504
              I think I paid $220 with hardware. Do a search in the Swap Shop and you will find several threads there that discuss cost.
              Thanks Eodman, I'll check into that. I tried bypassing the ESC and blew through the cooling hose and still got a lot of back pressure. And the hose routing looks clean (no kinks).
              There is a fine line between "hobby" and "mental illness."
              • peells
                • Jan 2008
                • 716
                I am glad you got your water flow problem fixed,
                I was reading above where you were concerned about the possibility of using stainless on your mount, if it was a good piece of stainless (USS steel not sure of the grade #s at this point) you would not have any problems with the dissimilar metal thing which causes electrolysis, the aircraft industry has been doing it for years, now if it was regular steel we would be talking electrolytic corrosion. and if a person was worried about it just use something to isolate the two parts( a little paint on the back side would do the trick), (which you wouldn't have to do any way it would have worked fine as is. when I worked on aircraft I would see this type of connection frequently.
                Peter Eells; Fun, and Helping others To Have Fun!!!
                http://rcboatsbypetere.blogspot.com/
                [email protected]
                • Chop
                  • Nov 2007
                  • 504
                  #23
                  I have some small pieces of 304L stainless and a few that are 316L stainless. I had forgotten about adding a "poision pad" to separate the two different metals.
                  Thanks.
                  • peells
                    • Jan 2008
                    • 716
                    #24
                    I doubt it would make any difference if you isolate the two.
                    [email protected]
                    • Chop
                      • Nov 2007
                      • 504
                      #25
                      Probably not, it was just a thought I had when I was making the piece.
                      • Chop
                        • Nov 2007
                        • 504
                        #26
                        You might have hit the nail on the head Eodman. I removed and measured the fitting for the water inlet - it was 3/16 of an inch long, the thickness of the motor cooling jacket (outside of the jacket to the outside of the motor) was the same.
                        I filed the threaded end of the nipple(s) down about 1/16" and replaced. When blowing through the pickup hose there was moch less resistance!
                        I will try it out at the pond tomorrow.
                        • Chop
                          • Nov 2007
                          • 504
                          #27
                          Cooling water is running good now and I've been playing with the boat. This is another fun craft - Scotty does good work!
                          The boat has a Hydra 240 ESC and I just bought a Castle Link to program it with. I had all the settings right, except one - The low voltage cutoff was set at 5.0, I don't remember what I raised it to but it was supposed to be appropriate for 4s lipos. I can't find the different setting values anywhere.
                          Now when I hook everything up and pull the throttle trigger, the motor only "twitches."
                          Any ideas?
                          • Viking
                            • Jul 2008
                            • 133
                            #28
                            twitch
                            You may have set the low voltage cut off too high. It should be 3.2volts per cell or for 4S 12.8volts.
                            check that it is set up for 4S that can do it too.
                            Viking
                            That Viking www.How2RC.com PULSO
                            Home made 36" DeepVee 50mph
                            • Chop
                              • Nov 2007
                              • 504
                              #29
                              Here are the current settings I’m using:
                              Cut off voltage: 12.0v
                              No Reverse
                              Reverse throttle amount: 12.5%
                              Motor timing: Normal 7
                              Start power: Low
                              Current limiter: Enabled
                              • Chop
                                • Nov 2007
                                • 504
                                #30
                                Anyone?
