I am working on a Skunk Works 29” Vee.
I bought a package a few months ago and am just getting around to putting it together. Unfortunately, this is turning into a full on build.
I have a few questions…
The motor mount broke loose during shipping so that has to be re-attached (those USPS guy’s must have been playing soccer with the box to have broken it loose!).
When I pulled the motor out (mount & all). I noticed some play between the rails and the rest of the mount. I tried to tighten it but the holes seem stripped. I can epoxy the two pieces together and be done with it or do it right and make a new piece. Question is, should I have it made from (soft) aluminum and risk stripping the holes again, or have it made from stainless steel? There is a slight chance of corrosion from dissimilar metals touching (the aluminum & S.S.), but I don’t run in salt water so it shouldn’t be too much of an issue.
The electrical setup is as follows:
KB36 11XL Motor
Castle Creations Hydra 240 speed control
and,
Elite 4S 4500 30c lipo’s (2 of them) to power it.
As I was working on it tonight I saw something written on the ESC, it said “20C/6SL.” Does the 20C refer to the max. “C” rating the ESC can handle? Note that I bought 30c lipo’s. I cannot find anything in the instructions that addresses the maximum “C” rating that the ESC can handle.
As long as I’m talking about the electrical part of it I might mention that the male bullets on the motor seem to be 4mm. They might be 3.5, but I measured them when they were not compressed. Will these be enough to handle the amps running through it (it has a 47mm 3-blade prop)?
The local hobby shop could not get 5.5 bullets but had some that were 6.5mm so I got those instead. I was planning on using them between the ESC and the batteries, and putting together a parallel harness to add run time if needed.
The ESC does not look waterproof at all. Should I pull the shrink tube off the ESC and spray it with insulating lacquer or spray on electrical tape? I do not want to cover the L.E.D. that confirms the ESC settings so that might be a problem. Where is it located? I could mask it and pull the tape off after I am done waterproofing it.
Let me know your thoughts.
KB36 11XL Motor
and,
