(6) GP style ML Boatworks sport hydros to be built...any interest?
  • cybercrxt
    • 2909
    #46
    Probably in the x452 range to start, see where the temps are, then move up.
    I got a tracking number stating the gp kits left my laser guy yesterday!!
    • flraptor07
      • Aug 2013
      • 2451
      #47
      I'm gonna go with a little hotter setup than that, I'm using the new TP 4070 1770kv. Dave @ HRC and I were measuring the motor up for cooling jackets the other day and the 4070 measures 107mm long so it's the same size as the Neu 1530, not the 1527 like we originally thought.
      • tlandauer
        • 5666
        #48
        What about Castle 1717? with the finned version, would that be too larger dia. wise?
        • flraptor07
          • Aug 2013
          • 2451
          #49
          I'm not 100% sure but I think it might be a little too big. Maybe Mike will answer that?
          • tlandauer
            • 5666
            #50
            Thanks, that is what I suspect as well, will wait for Mike's advice.
            • cybercrxt
              • 2909
              #51
              A 1530 would be bad as heck in these boats. I was running a 1527 1.5d in mine, running close to 70mph in the straights, and a cornering speed at 64mph exiting the turn. I set my SAW Q tunnel record at 79.5mph with a castle 1717 1650kv motor...I like that motor a lot! Choose Wisely, Choose Wiseeelllyyyy.....
                • 9488
                #52
                Nice
                that's the new Black can motor right?
                • 785boats
                  Wet Track Racing
                  • Nov 2008
                  • 3169
                  #53
                  Guys.
                  I thought I'd offer this info as a bit of a comparison which may or may not be useful.
                  I've run the following setups in mine. All on a Seaking 180 & a 6s1p 5000mah pack (we are not allowed to race 2p setups here in Australia.)
                  Tp Power 4060 1600kv with a Prather s230 prop.
                  TP Power 4060 1350kv with a prather s240 prop.
                  TP Power 4070 1440kv with a prather s240 prop.
                  The 1350kv set up was recorded (gps) at 111 klicks (69mph) in a 5 lap run.
                  Although not recorded, & I've only had one short run on it, the 1440 definitely "felt" faster.
                  I hope you guys love your new boats as much as I love mine.
                  Cheers.
                  Paul.
                  • tlandauer
                    • 5666
                    #54
                    Thank you sir!
                    I am as inexperienced as you can imagine, so any info and enlightenment is deeply appreciated!
                    • tlandauer
                      • 5666
                      #55
                      Thank you for the words of wisdom!
                      • flraptor07
                        • Aug 2013
                        • 2451
                        #56
                        Originally posted by 785boats
                        Guys.
                        Cheers.
                        Paul.
                        I'm sure we will Paul, Thank you for the setups. I'm going with the TP 4070 but the 1770kv version (cause I like the RPM) on 6s 2p and a SF 240 ESC. And I already have those stainless Prather props too!
                        • 785boats
                          Wet Track Racing
                          • Nov 2008
                          • 3169
                          #57
                          Should be a rocket with that setup.
                          • cybercrxt
                            • 2909
                            #58
                            Nice Paul! You never told me you were recording 69mph runs, very cool! Mike
                            Guys, I think..I need to check the tracking, that the kits may arrive tomorrow! :)
                            • flraptor07
                              • Aug 2013
                              • 2451
                              #59
                              I sure am glad mines first! I'm diein' here, can't wait to get it. I decided to get a different ESC, I've got a MGM TTM 28026-3 280.amp it's the bare bones X2 lite series. Rocket City has them for $284.00
                              • 785boats
                                Wet Track Racing
                                • Nov 2008
                                • 3169
                                #60
                                Thanks Mike.
                                I only put the GPS in it once. I'll let you know when I break 70mph.
