Glad to hear some positive headway Rick.
Maiden Runs - Insane FE30 & Insane Mono 34
A pic being worth a thousand words............how I'm measuring the trim tab position. In this case, the spot of the trim tab that is level with the bottom of the hull is 30mm off the transom. Makes it easy to get both trim tabs the same.
IMG_20140526_095712_upload.jpgComment
Well, I've backed off the trim tabs to the point that it's starting to chine walk. I assume that means I've got to add just a little more negative trim tab. Correct?
The ESC is getting VERY warm though. Not just caps and the ESC body, but the wires as well. Gonna start a separate thread on that.Comment
You could also try the strut up a bit to settle the hull in the water. But the warming ESC... Smaller prop?
Just looked back, you still running that 447/3? Try a 2 blader. Or a 445.
I also see that the stinger can't be raised without effort so still back to too much blade in water.Comment
No that is gonna float the nose in the air. I mean stinger up in relation to hull. It is a fine line between enough prop for the desired speed and and too much prop 'bite'. This is why I went strut on my Bling, I just had sooo much time into the DF with the stinger to get it right. I would try a smaller one and see if it will get settled. May get the heat issue fixed too.
Is it 'rudely' chine walking? Or just some?Comment
Some interesting data on the Hydro. Running a TP4050 2220kv on 4s1p and a m545 prop. Pulling much more current than the heavier mono. That's why I'm thinking the ESC in the mono could be pooched after being submerged.
I only measured 115F at the caps when I pulled it in so the logged temps were a bit of a surprise. The m545 might be too much prop though.
Untitled_2014_6_1_2.jpgComment
I used to run a Insane Mono just like yours.Comment
With the m445, my gut-o-meter is saying mid to high 40's. A few mph faster with teh x447/3. I was surprised that the m445 was able to push that heavy mono as fast as it did.
The ESC to Motor wire length is what came with each part. Neither Swordfish or TP are overly generous with their wires. The ESC is sitting right on top of the motor and to orientate the ESC to minimize the battery wires I'm needing all the ESC - Motor wires that were given.
The ESC - Battery wires are about 8". There might be 1" excess wire between the two, but I'm still playing with CoG.Comment
[ATTACH=CONFIG]116130[/ATTACH]
2014-06-02 11_17_29-DSC_0051 - Windows Photo Viewer.jpgComment
