Whiplash 40 Q Sport
  • ray schrauwen
    • 9471
    #46
    So, whats new Pete?
    Do you think a SF200 4-8S esc would do for me and my 1527 1Y clone by TP Power? What cells are you planning on using??
    Nortavlag Bulc
    • JRS Innovations
      • Oct 2010
      • 85
      #47
      Originally posted by Shooter
      The little plastic pcs in the kit are 10mm in diameter. There is a lip/flange on them. I wonder if the original intention was for the lip/flange to seal on the boot??? Moot point since we are all just sealing on brass tubing, but I'd still like to know.
      Hello Shooter
      Very Nice Build You got going on there.....
      When ever I design a new radio box I use the AquaCraft boots with those 10mm Plastic collars.
      I CNC into my box the OD of the plastic part and pocket down about .030"
      Then I rough up the plastic and CA it into the pocket. It works perfect.
      Also the Boots last a long time. very durable.
      Thanks
      Joe
      JRS Innovations
      • Shooter
        Team Mojo
        • Jun 2009
        • 2558
        #48
        Hey Ray. Not sure about that controller. The only experience I have with Q is using the Castle 240. I will be running a 1530, Castle 240, and the PULSE brand cells that I ran last year (helicopter guys use these).
        Joe - Thanks for the photo. That's a nice clean set-up. Seems like everyone (myself included) mounts the 'flange side' to the boat/box. I originally thought the the flange was to provide a larger diameter for the seal to stretch over.
        • Shooter
          Team Mojo
          • Jun 2009
          • 2558
          #49
          Oh...... forgot to mention. I really screwed the pooch on the first coat of epoxy on the outside. Not sure if it was due to a poor quality foam brush or just contamination. Mr. Ball set me straight on how to properly seal the boat. I had to sand the entire thing back down to the wood.
          • ray schrauwen
            • 9471
            #50
            O.k. how many Mah cells do you use in this rig and what are the special details when applying a finish coat of epoxy?
            I just have to put the bottom sponson ride pads on after some sanding and then skin it. Just got my Virginia Craftsman fins in the mail
            Nortavlag Bulc
            • oscarel
              • Dec 2009
              • 2130
              #51
              So, whats new Pete?
              SF200 should be enough. I fried one last race but believe it was my fault, didn't disable onboard BEC while using external supply. I normally run mine with T180. Most here run with less than 7000mah for heat racing.
              • ray schrauwen
                • 9471
                #52
                Thank you but, maybe do you mean the 220 as it has BEC and the 200 4-8S is Opto?
                Nortavlag Bulc
                • oscarel
                  • Dec 2009
                  • 2130
                  #53
                  It was 200amp 2-6s with BEC. Again, it wasn't the ESC's fault (this time) it was mine...
                  • ray schrauwen
                    • 9471
                    #54
                    o.k. I have one of those too. Brain fart.
                    Nortavlag Bulc
                    • Shooter
                      Team Mojo
                      • Jun 2009
                      • 2558
                      #55
                      I run 10,000mah....but my boat wasn't very competitive last year.
                      As for the finishing tips I got from Mike: The major difference was letting the resin sit, and then scraping it off with old business cards.... or using a squeegee as Detox suggested.
                      • ray schrauwen
                        • 9471
                        #56
                        Thanks Pete. Seems like 10,000 is a tad heavy but, your whip 40 will lift it easy. I wish I had planned ahead and made my inside stringers higher too!
                        Nortavlag Bulc
                        • oscarel
                          • Dec 2009
                          • 2130
                          #57
                          10000 is heavy but sometimes it's a good thing and can still be competitive.. I was able to fit using 3s TP's, 3 on their sides and one laying flat on top. I initially started with a Castle 1717 and a cupped X447 and now run 1527 1Y with ABC 2116. Here's a video Jesse J filmed a few years back.
                          http://forums.offshoreelectrics.com/...race-Dallas-Tx
                          • ray schrauwen
                            • 9471
                            #58
                            Thanks for the prop advice, gotta check video later, too busy right now. Thanks for the advice and info!!
                            Nortavlag Bulc
                            • Shooter
                              Team Mojo
                              • Jun 2009
                              • 2558
                              #59
                              Oscarel - That vid link isn't in the post anymore. Can you re-post it for us?? Thanks!
                              • detox
                                • Jun 2008
                                • 2318
                                #60
                                Cut and paste: https://www.youtube.com/watch?v=HPLlqC82G8M
