TWIN motor SV27
  • Avanti
    • Nov 2007
    • 1280
    #31
    side shot for RCprince
    esc wired up
    • RCprince
      • Jul 2007
      • 1637
      #32
      Cool, you might wanna try the Nitro SV props composites x437 I think they may be small enough for those motors, they come 2 to a pack
      • Avanti
        • Nov 2007
        • 1280
        #33
        the boat ran pretty good I can't wait to get some brushless power in her
        • hex-dj
          • May 2008
          • 238
          #34
          Nice! Seems to be running well. If you get those brushless I d like to know something. I will like to do a similar project ,but with a different boat some day. How do you put two brushless ESCs to run with only one reciever or perhaps a DSM reciever?
          • Avanti
            • Nov 2007
            • 1280
            #35
            I'm thinking one hydra 240 should do the trick
            or two smaller controllers and tie the receiver wires together
            (I have not thought it all the way through yet, but I know it is possible)
            the next step for me is a counter rotating shaft for one side.
            the props ride half out of the water like a true surface piercing setup.
            I also loved the way it sounded.
            my guess is it ran around 30mph with 12cell 3300nimhs.
            all my homemade parts held nicely too.
            • Doby
              KANADA RULES!
              • 7280
              #36
              One brushless controller and 2 motors will not work, you will need 2 controllers with the reciever leads wired together.
              Grand River Marine Modellers
              • hex-dj
                • May 2008
                • 238
                #37
                Thanks for the info Doby. I guess that a separate reciver batt. is needed right?
                • obrien
                  • Nov 2007
                  • 1264
                  #38
                  Doby you don't think you could use a hydra 240 to run twins since it has two sets of wire leads coming out of it?
                  • lonewolf
                    • Jul 2007
                    • 658
                    #39
                    the double wires are for handleing the current.. With brushless to need an esc for each motor, and run a "y" cable from esc's to rx.
                    Twin cat 9xl,... 29 titan 8xl,....37 in mono kb48 8xl.... 42 in twin elc cat project... 42 in gasser cat 260 modded zenoh''' planes and trucks....
                    • Avanti
                      • Nov 2007
                      • 1280
                      #40
                      Thanks for the info Doby & Lonewolf
                      • RCprince
                        • Jul 2007
                        • 1637
                        #41
                        • obrien
                          • Nov 2007
                          • 1264
                          #42
                          thanks for the info guys. It is good to know that I was wrong on that. I would have felt bad if Avanti had bought one controller and killed it.
                          • Avanti
                            • Nov 2007
                            • 1280
                            #43
                            Well this boat will be shelved for now as I am building a DF33 keep an eye on this thread in the fall
                            • Brushless01
                              • Apr 2010
                              • 487
                              #44
                              You put the motor mount in the wrong way round !!
                              Prince 25 8XL,Delta force 29 8XL, SV27,Rio 51,Mini Rio,Stock Miss Geico m445,ERBE,Baja 5B SS, Hyper ST, Castle Emaxx.
                              • Avanti
                                • Nov 2007
                                • 1280
                                #45
                                the mount was reversed so the twin motors would fit
