Was just going to order the hrc but my buddy is a plumber and had a bunch of pipe laying around. I got 2" scrap off of him for free and already had the brass. After a little modifying I got the piece to fit with just a 2 mm gap all the way around. I cut two little pieces to use as shims on the front and back and also to allow the Cu to be in direct contact with the motor can for max heat transfer. I used silicon to seal it up. Just tested this morning and no leaks. Now all I have to do is install it and see if it cools better then AL. I couldn't extend it all the way to the wires because the extra diameter from the jacket would have been in the way with the mount I'm using.
Opinions welcome
Opinions welcome
