Okay, so I started building the tub last night and whether I was tired or what, anyway I glued in the first two formers and rear transom and discovered a bit of twist in the tub as it has been built so far.
Now I plan to purchase some angle aluminum to build the jig for the rest of the tub construction.
Will the jig help to alleviate the twist or do I need to do something else?
Also there is no info regarding the jug construction. I have to assume, and you know what that means, the jig is built to the same width as the tub is supposed to be ....which is?
I have the JAE hardware order from the guys at Zipp Kits and haven't decided on a motor yet, whether to go with the UL-1 or a Leo 3650-2290 and 4S pack. I have a Feigao motor at 4761 KV but will not use it. I also have a Sea King 90 ESC which I plan to use with which ever motor I choose.
I have the tubs partially built now and ready to add the rest of the sheeting. Otherwise everything seems to be going well.
This, along with building a 1/5 scale Piper Cub (Sig) and an Alien Aircraft Super Dragon Sea Plane is keeping busy.... sometimes it seems I'm spinning my wheels for taking on too many projects at once.
Thanks and cheers
Now I plan to purchase some angle aluminum to build the jig for the rest of the tub construction.Will the jig help to alleviate the twist or do I need to do something else?
Thanks and cheers
