BBY Micro Turbine Hydro for SSSH
  • RandyatBBY
    • Sep 2007
    • 3915
    #451
    Thanks Jim that is what I was talking about.
    Randy
    BBY Racing
    • Waksk8n
      • 134
      #452
      I didn't get to run last weekend the winds were to high. Jim your motor looks good I'm going to build my cowl up for the shovel.
      • Waksk8n
        • 134
        #453
        Made the first run today. Everything went well. Now its time for paint.
        • peells
          • Jan 2008
          • 716
          #454
          Well lets get some pictures up
          Peter Eells; Fun, and Helping others To Have Fun!!!
          http://rcboatsbypetere.blogspot.com/
          [email protected]
          • Dr. Jet
            • Sep 2007
            • 1707
            #455
            UPDATE:
            After nearly a decade of doing something else, I've decided to get the BBY Micro Turbine on the lake. Just waiting for a modern radio to arrive in the mail.
            A nation of sheep breeds a government of wolves
            • JimClark
              • 5907
              #456
              Welcome back Dr Jet
              Billy Graham
              • fweasel
                master of some
                • Jul 2016
                • 4286
                #457
                Cool!
                Vac-U-Tug Jr (13mph)
                • RandyatBBY
                  • Sep 2007
                  • 3915
                  #458
                  Originally posted by Dr. Jet
                  UPDATE:
                  It came out great! Nice to see the little boats still with a life.
                  Randy
                  BBY Racing
                  • peells
                    • Jan 2008
                    • 716
                    #459
                    I still drag mine out once and awhile my orange and black is like 9 years old but still hits speeds of up to 49.9 mph the last time out it was like 45.0, I have one on the work bench collecting dust and have been thinking about dragging it out and finishing it, it should even be faster.
                    [email protected]
                    • RandyatBBY
                      • Sep 2007
                      • 3915
                      #460
                      Man that is flying with a little boat. Bill had one doing 58MPH
                      I lost my little pond so I do not run mine either. It has a little hacker motor in it actually a real long one. :-) I would run it in golden gate pond but never have the time. It is mostly a matter of energy at 69.
                      Randy
                      BBY Racing
                      • Dr. Jet
                        • Sep 2007
                        • 1707
                        #461
                        Hey Randy, Good to see you are still around. I expect my 2S setup to be in the 30mph range, and I plan to post some videos (if it works....) I'm using a 2mm driveshaft and it is currently supported by a ball bearing at each end. I'm getting some wobbling in the shaft, so I plan to install an intermediate bearing to stop that wobble, so it will be a little while before I get it on the pond. Stay tuned.
                        • Dr. Jet
                          • Sep 2007
                          • 1707
                          #462
                          Well, I finally ran the Micro Hydro. I had to go back through this post to see what motor I have (3850 Kv fan-cooled outrunner). Of course, this particular motor is no longer available, but there are countless others of the same size and Kv. I first tried it with a Graupner S-29 prop (29mmx1.6 pitch) with one of my old 2S packs. It was pretty ho-hum. Then I decided to put an S-31 on it to see if that would perk it up. I also swapped battery packs for a different 2S. I soon discovered that the first pack was way low on voltage. This thing literally flew. It was a bit of a challenge to keep it on the water. After retrieving the flipped boat, I went back to the S-29. It wasn't quite as fast, but it was 100% rock-stable. It cornered like a dream, was plenty loose on the straights and had absolutely no bad habits. This might be my favorite micro hydro of the bunch! This boat on 2S is about a quick as the Small Bolt is on 3S with a good prop, and the BBY hull has much better stability and handling.
                          Next time I go to the pond, I'll see if someone will video it. It's a hoot! Kudos to Randy for a great design: Shallow tunnel. WIDE sponsons. Perfect!
                          • RandyatBBY
                            • Sep 2007
                            • 3915
                            #463
                            Well thank you. I can make more.
                            Randy
                            BBY Racing
                            • Dr. Jet
                              • Sep 2007
                              • 1707
                              #464
                              Hey Randy, glad to see you're still around. I heard about your bike crash ( Ouch!!)
                              I'm trying to resurrect the SLOBS (Santee Lakes Old Boaters Society) and the number of decent available micro hulls is limited. If I can stir up some interest, I'll let you know. I still have the files for laser-cutting the internal plywood bracing, so it would make building a fleet of them a breeze.
                              By the way, did I mention my hull turned out as stiff as a board? That's one reason it handles so well and predictable.
                              • NativePaul
                                Greased Weasel
                                • 2760
                                #465
                                Not scale hydros, but there are Naviga Mini Mono, Mini Hydro, and Mini ECO classes now, so there are a bunch of sub 450mm stepped monos and outriggers, and sub 430mm flatties available from Europe and Asia.
