I've been working hard with this Project so that speed is quite good but doesn't make justice for the real potential of this boat.The flexcable broke near the collet maybe because the MBP was seriouly damaged by the motor screw.....and yes I use loctite everywhere but you must have heard of Murphys law .Gill
GRX SAW RiGGER
If you lost a motor screw, there was a strong possibility the motor was not rigid and had enough misalignment through vibration to break the cable. It's happened to me.Tyler Garrard
NAMBA 639/IMPBA 20525
T-Hydro @ 142.94mph former WRComment
saw rigger
tyler, its amazing what vibration can do. on a solid shaft setup with my neu 2230 i used octura u-joint (dog bone setup 1/4 " solid shaft) the hardened pin (on the male part ) removed itself from the joint. tried to remove pin from new joint had to hit as hard as i could with a hammer and punch to remove. happened twice gave up on u-jointsComment
Tyler only one of the four screws came out and mangled the rear of the collet so maybe I forgot to loctite it I don't know.The flexcable failure is unknown as it was a new Hughey shaft but in saw everything is possible.I only use 3/16 shafts on my Fe boats .Yes it is a Neu 1527 2300kv on 6S so at least in theory speeds up to 125mph can be reached.GillGO FAST AND TURN RIGHT !
www.grsboats.com.brComment
Yes it is 1/4 "stuffing box. will post pics of the broken parts.GillGO FAST AND TURN RIGHT !
Tyler only one of the four screws came out and mangled the rear of the collet so maybe I forgot to loctite it I don't know.The flexcable failure is unknown as it was a new Hughey shaft but in saw everything is possible.I only use 3/16 shafts on my Fe boats .Yes it is a Neu 1527 2300kv on 6S so at least in theory speeds up to 125mph can be reached.Gill.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8sComment
Put the collet on the lathe just to rework it...won't use it but will make a test to see the grip on the rotor in a low kv leopard...changed for an alu pushrod with balls for the rudder .....the first broken flexshaft in months.In the core of the shaft there are some signs of rust. GillAttached FilesGO FAST AND TURN RIGHT !
Gill what are your thoughts & experience on the prop water pick ups slowing boats down because of interfering with the water leaving the prop. As some say it slows boats down over say rudder pick ups or flush hull pick ups (in monos or cats & not riggers). Martin.Comment
Gil,
Did the break in the flexcable occur in the section between the collet and stuffing tube? It could have just snapped from power.......
TGTyler Garrard
Martin all my nitro saw riggers were and are equipped with steelblade rudders and auxiliary water pick ups with great results.For this paticular boat it was inttended to use also a steel blade rudder but I had no time to make one so it feeds the motor water cooling.I don't think there is a loss of speed as they are Always positioned above the shaft line on my boats.The other types i never got a try.Tyler the break occured half na inch up the exit of the stuffing box .When I got this cable it came rusted in the bag so there must be some corrosion inside the core......GillGO FAST AND TURN RIGHT !
