hi gil, looking foward to videos of your boat. i built a homemade rigger with leopard 4082 2000kv 6 -s 5000 ma seaking 180 esc. rtr weight 8 lbs ( high lift design ) ( not for ultimate speed obviously ) couple questions if you dont mind. good starting props for oval racing and do you think i need cooling mod with oval racing setup? also do i need thrust bearing at the motor mount or will motor handle the thrust ? thanks
GRX SAW RiGGER
Your set up sounds good....same I had with my Jae FE .Octura 1450 44mm(3,5cup) and 46mm cup 3,4 are good starting props for heat racing.You can improve your cooling but using the Leopard water jacket I think you are ok.I'm in the middle of a process making big changes on my boat and videos will be posted soon.GillGO FAST AND TURN RIGHT !
www.grsboats.com.brComment
Personally I don't use trust bearings on my NEU motors now but I think they won't hurt your performance at all.GillGO FAST AND TURN RIGHT !
Today in the morning went to the lake for tests and a pushrod failure cause a big take off during acceleration causing the loss of the rear central sponson......and damage to the rudder blade ! Well some work for the next days for our big event in two weeks. GillAttached FilesGO FAST AND TURN RIGHT !
That was some awfully rough water to try and go fast in. Which lake in Brazil is the SAW event scheduled?
TGTyler Garrard
NAMBA 639/IMPBA 20525
T-Hydro @ 142.94mph former WRComment
I know Tyler.... it was my fifth try even in rough water and boat was handling good(with limited throttle) but the main problem was a pushrod failure in the servo horn...changed for an aluminium one now.This event is hold in a private property with a 1800ft long lake.Btw if you don't mind which esc do you use with the Neu 1527? Thanks GillGO FAST AND TURN RIGHT !
Ok I only saw your reply on my other tread now.Thanks GillGO FAST AND TURN RIGHT !
Good luck in the event, let us know how it runs.
TGTyler Garrard
thanks guys will post the fix in the next days.I decided to change the rudder assy for a new one and borrow an Ice 240 from a brother so almost ready to get back to water.GillGO FAST AND TURN RIGHT !
boat's been fixed: cleaned the botton,made a new Ski that was glued carefully and received three laywers of 48gm fiber cloth per side.Now this area is really strong.Waiting for the ICE 240(bought from OSE) and rudder.In this meantime will make more tests with the heat race version.GillLast edited by grsboats; 05-02-2013, 10:51 AM.GO FAST AND TURN RIGHT !
Boat ready to run weights 106,2oz : Leopard 4082 2000kv 6S 45C Nano and T-180 . with new c.f turnfin thanks GillGO FAST AND TURN RIGHT !
