So I bought this hull and some of the parts of Rundog a while ago. I ordered up the rest of the hardware and had to re-order a couple different things once I got the hull and realize how tini the transom actually was! Made me think a mini wasn't the best idea for a first build. But it turned out pretty good once I got the right hardware. The only think I wish I had done differently would have been to put the rudder push rod through the transom between the rudder and strut. But thats what I get for mounting some hardware without having everything. I made the battery mounts out of a carbon sheet and the servo mount out of aluminum which worked out well and some other details like how I attached the hatch etc. I did a bad job painting the windshield though so I have to re-do that, wrong paint.
I have run it 4 times and have the CG and strut angle running well, I need to try some other props now though. I was using a 32mm CNC HK prop which was not bad but I want more pic up from cornering and full stops. I was only seeing temps of 75-80 so I think I'm safe to prop up. Just balanced an X632 which I'm sure I will have to detounge, but I will try it first. Thinking a detounged X435 would be good.
I'm open to help with set up!
I run duel Nano-tech 2s 2200mA 40c batteries, the traxxas replacement ones which are tini
Leopard 2845 4700kv
Turnigy 60A ESC
Traxxas waterproof mini servo
Have to figure out how to rotate pics..
Leopard 2845 4700kv
Turnigy 60A ESC
