AuqaCraft miss Vegas deuce~electric conversion
  • borgie
    • Dec 2012
    • 101
    hello
    this is my first proper build ,the boat that i,am using in an AuqaCraft miss Vegas deuce ,the specs of this boat are (if you don't know) 32.3 in (820 mm) long and the beam is 13.8 in (350 mm).
    the electrics that i,am going to be using are:
    1x turnigy xk4074 2000kv motor http://www.hobbyking.com/hobbyking/s..._for_Boat.html
    1x turnigy t-180 esc with cap bank
    i have not got any of them items yet
  • borgie
    • Dec 2012
    • 101
    in side all stripped out
    • devo
      • Aug 2012
      • 146
      I built one just like it and it's posted in the build threads here somewhere. Are you going to lay carbon fiber in the bottom of the hull? I would highly reccomend it as these boats are not very stiff and benefit very much from it. Im running a leopard 3674 1700kv on 6s with the stock esc out of the new blackjack which is only rated at 80 amp's but consistantly holds up to the 6s I run. I have 4 of the turnigy nano 3s 65c 3000mah that I run two sets in series which gives me 6s and fits nicely in the boat, good luck with your build, and if you need any pics of mine feel free to ask.
      • borgie
        • Dec 2012
        • 101
        yes i,am going to put c/f inlay and how did you mount your servo
        thanks
        • devo
          • Aug 2012
          • 146
          We used of of the standard size hitek waterproof servos and on of the machined aluminum mounts and just epoxied the mount in place when the final coat of epoxy was poured in.
          • devo
            • Aug 2012
            • 146
            Here is a pic of how we installed it
            • borgie
              • Dec 2012
              • 101
              ok thanks i was gonna put it in the sunk area so the rod would go where the exhaust is and how big are the rudders on the because i got mine with no rudder
              • TheShaughnessy
                • 1431
                roughly 4 inches for the rudder
                • borgie
                  • Dec 2012
                  • 101
                  will this be ok http://shop.rcboatbitz.com.au/index....roducts_id=241
                  btw its my local hobby shop
                  • drwayne
                    • May 2008
                    • 2981
                    perfect, Borglet.
                    • borgie
                      • Dec 2012
                      • 101
                      ok thanks ''doc''lol
                      • Heaving Earth
                        Banned
                        • Jun 2012
                        • 1877
                        Borgie, that's an ok rudder. Perfect size. Only downfall is they have a bit of play in them from my experience. The speedmaster mini rudder is much better built if you don't mind spending the extra cash. The tolerances in the speedmaster make it a much tighter rudder with little to no slop.
                        • borgie
                          • Dec 2012
                          • 101
                          i run this rudder on my 28'' mono and there is only 1mm of
                          play and does anyone know about the turnigy motors id the are any good
                          • Heaving Earth
                            Banned
                            • Jun 2012
                            • 1877
                            Oh well maybe it isn't the same rudder I got. Mine had alot of play in it.
                            • Heaving Earth
                              Banned
                              • Jun 2012
                              • 1877
                              Yes that's a good motor. I've had luck with them
