DaVette Aspect Shallow 42" Hull - New Build - Motor selection and misc. help needed
  • gyrotron
    • Jul 2012
    • 481
    #91
    Originally posted by jcald2000
    Cable slipping in collet, did you solder the end of the cable? Thats why it is hard to get on plane and only 60 amps.
    jcald2000/Lenny,
    I checked the coupler this morning as suggested by you guys and I was able to give it another turn and tighten it up some more. I won't give up on the prop just yet.
    jcald2000,
    Yes the end of the cable was soldered, but you are right on the drawn amps., I was expecting something over 150 or so.
    • lenny
      • Sep 2010
      • 4293
      #92
      Is that a kintec coupler and is it a 3 piece or two piece ?
      Something does not look right on it,
      Like it is bottomed out on the threads.
      Take it off and post some pictures of it if you can.
      ? ONLY IF THEY WORK
      • gyrotron
        • Jul 2012
        • 481
        #93
        Lenny,
        It is the Kintecracing 2 piece collet.
        • lenny
          • Sep 2010
          • 4293
          #94
          Sorry,
          I was writing the same time you were replying.
          So got the coupler to take a hole turn to tighten it more.
          Will you be running at dusk some times,
          I was thinking of some scale lighting for the thing.
          It would look like a rocket exhaust if you added a couple LED there,
          And a bow light.
          ? ONLY IF THEY WORK
          • lenny
            • Sep 2010
            • 4293
            #95
            Ok,
            Some times the couplers fingers are not opened enough.
            And do not bite the flex shaft good and need to be modded some,
            So they will close a little better on the flex shaft.
            ? ONLY IF THEY WORK
            • RaceMechaniX
              • Sep 2007
              • 2821
              #96
              Here is a detailed view of the same data:
              The motor and esc are barely breaking a sweat. Have you confirmed the coupler was slipping?
              Tyler
              Tyler Garrard
              NAMBA 639/IMPBA 20525
              T-Hydro @ 142.94mph former WR
              • gyrotron
                • Jul 2012
                • 481
                #97
                Tyler,
                It looked like the coupler slipping was causing the collet heating up. I made adjustments, will run her tomorrow and report back. How did you manage to get the data log to look like that?
                Thx
                • lenny
                  • Sep 2010
                  • 4293
                  #98
                  Just do a short run and check the temps,
                  If all good run a little longer and check again.
                  Good luck with the runs.
                  ? ONLY IF THEY WORK
                  • gyrotron
                    • Jul 2012
                    • 481
                    #99
                    Thanks Lenny. I'll let you know how it goes.
                    • RaceMechaniX
                      • Sep 2007
                      • 2821
                      #100
                      Just click, drag and release like you are making a sqaure and it will zoom in on that set of data.
                      TG
                      Tyler Garrard
                      • gyrotron
                        • Jul 2012
                        • 481
                        #101
                        TG
                        Do I have to clear the data log everytime I run the boat? What is the max amount of data runs will the ESC be able to store? Thx.
                        • RaceMechaniX
                          • Sep 2007
                          • 2821
                          #102
                          On the loggin tab it till tell you how long the data will record for before it starts to over write the oldest data. Yes, you should save and then delete old data. I also prefer to log at 10Hz for the best resolution on data.
                          Tyler
                          Tyler Garrard
                          • gyrotron
                            • Jul 2012
                            • 481
                            #103
                            Today's run was a success. After the adjustments I run her in two consecutive sessions of 2 minutes each and what a difference in acceleration after tightening up the coupler (no collet heating up or smoke this time around). The first two minutes I run her on the 52mm prop and the other two on the 59mm prop to see the difference. Temp was on the high 90's hitting the low 100's. This time the props were biting well. I did like the 59mm better but I would like to try a 2 blade Octura to see how the acceleration reacts. I finally was able to have some fun with her today. As soon as the money pit recovers I'll get a Voltron GPS to find out how fast she's going.
                            • RaceMechaniX
                              • Sep 2007
                              • 2821
                              #104
                              The data looks better, but one of two things are occuring; You are not pulling full throttle or your esc is not calibrated correctly. The motor power out should be much closer to 100%.
                              Here are detailed views of the data. Graph on the left is the 52mm and graph on the right is 59mm.
                              Aspect 2012 on Proteus 910kv 8s2p_52 props 03-18-13.jpgAspect 2012 on Proteus 910kv 8s2p_59 props 03-18-13.jpg
                              Tyler Garrard
                              • gyrotron
                                • Jul 2012
                                • 481
                                #105
                                [ATTACH=CONFIG]95516[/ATTACH][ATTACH=CONFIG]95517[/ATTACH]
                                Tyler,
                                You are correct, I am not pulling full throtle because the pond is too small. I was able to comfortably run my Revolt30 and Blackjack29 on my community pond but this boat goes so fast that the length of the pond doesn't allow me to open it up full throtle. I would say I was able to go close to 3/4" throtle at some point.
