My attempt at building the Mean Machine
  • lenny
    • Sep 2010
    • 4294
    #31
    That looking real good Tim,
    I have one That needs a lot of tlc to build some day.
    This thread will help me down the line and others to.
    ? ONLY IF THEY WORK
    • tlandauer
      • 5666
      #32
      Thanks Lenny, I am learning, and I know you are very creative too, so I can't wait to see your build!
      • TheShaughnessy
        • 1431
        #33
        Not that it matters cause you already installed it but I've crashed my boats more then a couple times and never had the stuffing tube get damaged.
        • tlandauer
          • 5666
          #34
          Originally posted by TheShaughnessy
          Not that it matters cause you already installed it but I've crashed my boats more then a couple times and never had the stuffing tube get amaged.
          Thanks, I am sure I over did it, since this is my second build, I have to accept a learning curve, you guys have been a great help, I am enjoying the building as well as the learning experience!
          • tlandauer
            • 5666
            #35
            Got the servo mount, measured the rod and installed a 1/4" brass tube as rod sleeve. The stuffing tube is rigid and I tried to adjust the strut , it is good to see NO flex from the floor. The tube has enough flexibility to go either way.DSCN2918_2328.jpg
            BTW, the extra "floor " is a prototyping board from www.twinind.com , in retrospect, I should have cut it down, it is too large. This is very strong stuff, much better quality than the Radio Shack ones.DSCN2912_2326.jpgDSCN2944_2403.jpg
            Inside transom, with water inlet installed:DSCN2925_2386.jpg
            • tlandauer
              • 5666
              #36
              I had to shorten the wires from the ESC, and make a "T" shaped parallel plug. Much of my ideas are inspired from Dana's build!DSCN2932_2393.jpgDSCN2940_2400.jpg
              The boat is 80-85% finished, I need to paint the windshield, have NO idea how, also, one of the BEST features of Dana's boat is his sub hatch, I got to admit I will have a hard time duplicating that feat!
              Here are some pictures as of now:DSCN2951_2411.jpg DSCN2955_2415.jpg
              • justski
                • Sep 2012
                • 230
                #37
                looking good
                • tlandauer
                  • 5666
                  #38
                  Some more:DSCN2952_2412.jpg DSCN2953_2413.jpg DSCN2957_2417.jpg DSCN2954_2414.jpg.
                  Any advices and/or input will be appreciated.
                  Also, if you happen to read this, Dana, do you have trouble with your Tactic Radio? I hate to drill a hole for the antenna, but the hull is lined with CF, I am not so sure what to do? I have either Tactic or Spektrum standing by.
                  Thanks for looking, guys.
                  • carlcisneros
                    • Jan 2010
                    • 1218
                    #39
                    Tlandauer;
                    looking good guy.
                    suggestion,,,,,,,, replace the rudder push rod with one with an "S" bend in it instead of a "Z" bend.
                    The S bend is stronger and won't break like the Z bend CAN (at times after a while) at the 90degree bends.
                    This is just a suggestion.
                    • tlandauer
                      • 5666
                      #40
                      Originally posted by justski
                      looking good
                      Thanks, justski! hopefully I will be putting the finishing touches on soon, in for a busy spell though.
                      • tlandauer
                        • 5666
                        #41
                        Originally posted by carlcisneros
                        Tlandauer;
                        looking good guy.
                        The S bend is stronger and won't break like the Z bend CAN (after a while) at the 90degree bends.
                        OK! Thanks for the great advice!
                        • lenny
                          • Sep 2010
                          • 4294
                          #42
                          Looking good,
                          But that rudder look really long in the picture.
                          Windshield, Just get a decal from monojeff or check with Make-a-Wake he has done some nice painted ones.
                          ? ONLY IF THEY WORK
                          • tlandauer
                            • 5666
                            #43
                            Lenny,
                            Yes, I have to trim it sometime later, I read from a post by Properchopper that the general practice is to leave 2.5 inch below the sponson, and that is just below the water pick up hole. With this length I will be dragging the entire bottom of the lake!
                            I will ask Monojeff, thanks for the reminder!
                            • justski
                              • Sep 2012
                              • 230
                              #44
                              i am done with mine but i have to wait till spring to run mine .well i am going to take it all back apart and get it painted then i am done ..so i guess i am going to build another one
                              • tlandauer
                                • 5666
                                #45
                                I got the sub hatch done ( turned out by far the most challenging aspect of the build ) I got lazy and did not want to trim a bottle , found some soap mold from a craft/hobby store. The front just clears below the outter hatch dome () I used a combination of Goop E-6000 and Poly-Zap by Pazer---they work on Lexan, but dries faster than the Goop and remain flexible as well.DSCN2960_2420.jpg.
                                painted the windshield: first primer, then Graphite Mica metallic, both from Dupli-Color : DSCN2964_2424.jpg, DSCN2966_2426.jpg, DSCN2967_2427.jpg.
                                It's been a blast to build this one, thanks for all the great advices and inputs!
