Ok, I got hooked on this cat because of a thread regarding the MM. I am most impressed with what Dana did with his build, my attempts here are what I really liked about his build starting from the hatch.
My V1 hatch had to be sanded a bit for it to fit:DSCN2725_2173.jpg. I also reinforced the sides with FG tape:DSCN2727_2175.jpg
I am using Carbon fiber rod from my heli as studs from the hatch going into the hull:DSCN2728_2176.jpg, will JB Weld the studs.
As for the receptical: I got 5/32 K&S brass tube, cut two 30mm tube and crimped the ends and sealed with solder, CA'ed in the hull for position and will Epoxy from inside to make it strong and water prove.DSCN2733_2181.jpg,DSCN2737_2185.jpg.
