Very nice Bruce, whats the length by the way?
Dumas Scarab 377 New Build Electric
NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:
http://forums.offshoreelectrics.com/...est!&highlight= -
Thanks ... hull is 39 3/4" tip to upper transom. There is a bit of reverse rake to the transom so the vertical line from the bottom would probably make the hull 40" overall (not including hardware) Width at widest is 11" ... at transom is 10 3/4".Comment
Grey primer ...
First coat of primer. Wet sanding tomorrow and I'll see if it needs more prep.Attached FilesComment
