MHZ Mystic 1380mm build
  • nata2run
    customcfparts.com
    • Nov 2011
    • 1837
    #196
    LOL @ Chris, lots of machines I wish I had. Never thought the machines I have were going to be used for boats.
    @ PF3X, thanks for the compliments.
    Anyway, didnt have alot of time today to work on the boat, but got some electrical done plus the "Star" for the motor (Enables the motor in WYE mode and can be use for 8s around 1370kv, compared to Delta 2365kv i think) I also got the leads wrapped with mesh to hide the black, red, and white. And for minor protection. Next will be some more water proofing and mounting the ESC's 5-8 more hours and she's good for her maiden.
    Visit www.customcfparts.com | Custom Boat Building | Custom Carbon Fiber Parts | Custom Graphics | LMT Premium Dealer | MGM Premium Dealer | YouTube | Facebook
    "Follow someone's footsteps and you will always be a step behind"
    • nata2run
      customcfparts.com
      • Nov 2011
      • 1837
      #197
      Hi everyone, trying to work out the ESC's hmmm they fit fine but by doing this will have to extend the battery leads.
      Worse case they have to be top mounted. They also fit in the sponsons behind the motors :) ...ahh well still thinking
      • Remmie81
        • Apr 2012
        • 134
        #198
        Cant you put the ESC's sideways?
        Then connect the lipo thats in the left sponson with the right engine and vice versa.
        Then you can have the minimum wire lenght possible I think.
        But I dont know if that will fitt under your awesome carbon work.
        Grtz,
        Remmie
        • nata2run
          customcfparts.com
          • Nov 2011
          • 1837
          #199
          Remmie, I wish, but the holding screws are in the way. If I was able to fit them that way "if I modify" I don't think it would look very good as you would see the ends? I wonder how bad it would be to extend the wires 10cm 8guage? How much power would get lost? And how hot? I have tried behind the motors, it don't look bad.
          • drwayne
            • May 2008
            • 2981
            #200
            put them on the wall behind the escs.
            see brusier77 daytona thread where he placed the FC esc for example.
            W
            • nata2run
              customcfparts.com
              • Nov 2011
              • 1837
              #201
              Originally posted by drwayne
              put them on the outside wall behind the escs.
              W
              That's what I ment about the behind motors "parallel to the motors" if you look closely at the picture there is a black strip of Velcro next to the motor. It don't look too bad.
              • Remmie81
                • Apr 2012
                • 134
                #202
                Ok if sideways is not possible then I would mount them on the walls between the motors and batteries if possible.
                Then your tunnel stays very clean, you can design something new to make mounts and covers for them on the sides.
                everything is lined-up then and you can go with short wires.
                This was my idea for my MHZ 114 as well.
                • drwayne
                  • May 2008
                  • 2981
                  #203
                  TFL56 for SF300A
                  • Remmie81
                    • Apr 2012
                    • 134
                    #204
                    LOL, at least we are all talking about the same solution
                    • nata2run
                      customcfparts.com
                      • Nov 2011
                      • 1837
                      #205
                      Wow, they are big and heavy esc's. I have to think a little more as I want it to look as nice as possible.
                      • Remmie81
                        • Apr 2012
                        • 134
                        #206
                        Just an idea but if you would put velcro on the walls and on the ESC's, then you can always remove them in case you need to.
                        Then if you make these stands (like the ones you have on your tunnel were the bolts of your carbon plate go into) and mount
                        them on the walls you can put a carbon plate in front of the ESC's so they are almost not visible.
                        So the same idea as you have now on the tunnel but then on the walls of the sponsons
                        • drwayne
                          • May 2008
                          • 2981
                          #207
                          Hey Kent
                          Joe@mbp-de just invoiced me for the pair of click drives !
                          woohoo.. !
                          on their way ... !
                          23.58 here atm
                          g'nite !
                          • Chrisg81983
                            • Jul 2011
                            • 1556
                            #208
                            @ w those click drives are very nice. some people say he will not ship to us, but I have no problems. @ Kent I would do the esc's like bruiser did in his daytona how is the vinyl coming along
                            • nata2run
                              customcfparts.com
                              • Nov 2011
                              • 1837
                              #209
                              @ Wayne, woohoo good to hear, sadly when they get here you may loose them to me :) .!!
                              @ Everyone, the plan was to have them under the carbon....."I WILL MAKE THEM FIT" who says you can't trim a little here and there LOL.
                              @ Chris, you have PM
                              • nata2run
                                customcfparts.com
                                • Nov 2011
                                • 1837
                                #210
                                Thats not a bad idea, will do as my last way out if I cant fit them any other way, I would then cut the same pattern in them as on the plates but have them light up when the ESC's are armed :)
