This is my first attempt to build a FE boat from the hull up to rtr.
I am starting with the Insane Boats 34" mono hull. My goal is to create a formidable contender to run with my 31" Rico built by friend and fellow OSE member rearwheelin'
The Rico corners either direction like on rails and does just under 50mph.
Hardware is Speedmaster 40 except for custom large turn fins and Accutech trim tabs. Today I drilled the holes in the transom, so the hardware is all loosely held on right now, ...we will get to things like strut angle adjustment later. I will be using .187 flex and starting with a x445 prop.
Powerplant is an overkill, but heck I think I can keep the weight at 9lbs, I know the hardware is plenty large enough, and I have experience with it in other boats. So I'm dropping in a Castle 1717 1577kv brushless, a T-180 with extra caps and my special cap cooler(to come later) and Turnigy 6s1p 5000mah 40c.
I'm using 3mm carbon fiber for the motor mount sides, a battery tray, transom reinforcement, and probably a center mounted esc plate.
Here's some pictures to start ...I have plenty of questions, I don't mind trial and error, welcome constructive criticism, and as you can see I definitely jumped in head first. You'll see the first novice mistake is not having all the right size drill bits and accidently letting the larger bits grap and take some gelcoat with it
