41" Delta Force Racing Build - Nitro to Electric
  • Make-a-Wake
    FE Rules!
    • 5554
    #76
    Originally posted by Drax21
    What is the reason for the made up jumper connectors?
    The motor has 8mm connectors and I had to go from 6mm to 8 somehow...............
    • Drax21
      • Jul 2011
      • 1021
      #77
      Ah right I get ya. My motor should have bare wires when it arrives so I would probably be better off just sticking 6mm male connectors on them, right?
      Everything that has a beginning, has an End
      • Make-a-Wake
        FE Rules!
        • 5554
        #78
        Yep
        • Drax21
          • Jul 2011
          • 1021
          #79
          Getting the hardware on the boat now. Stinger holes have been drilled but the screws they sent me don't go through the transom.....too short
          I was going to use the original hole which the steering rod comes through but the baseplate of the rudder would be touching the top of the stinger... Any ideas other than drilling another hole a bit more right??
          Also if any of you say with an osprey hull could give me measurement of where the trim tabs are from the corners that would be great.
          • martin
            • 2869
            #80
            From the edge of the chine its 36mm to the outer edge of the tab also from the centre of the hull its 45mm to the inner edge on either tab.
            • Drax21
              • Jul 2011
              • 1021
              #81
              Cheers Martin. Here's some pics with the trim tabs mounted. Will mount the rudder near the same place that HK do on the osprey.
              If you could post a pic of the transom that would be helpful
              Thanks
              • martin
                • 2869
                #82
                I dont have any pictures of mine but if you go to horracing.com then to the 41" deep v theirs clear picture of the transome.
                • martin
                  • 2869
                  #83
                  The hor pics are the same pics as the HK ones.
                  • Drax21
                    • Jul 2011
                    • 1021
                    #84
                    Thanks for this. There isn't going to be much room left on my transom The osprey looks to be larger at the back.
                    The stinger has a large base plate and the trim tabs and rudder are the same. Getting the screws to mount the stinger tomorrow, then I will get the rest of the hardware on as well.
                    Motor should be here in a couple of days. Still have to decide on batts but from my previous tests I'm pretty sold on the Winmax series.
                    • Make-a-Wake
                      FE Rules!
                      • 5554
                      #85
                      Drax, the placement of the trim tabs is "spot on" in my opinion...........not to far in or out............... I have made the mistake of putting them too far either way and had to remount them.
                      • Drax21
                        • Jul 2011
                        • 1021
                        #86
                        Thanks The Left One is actually mounted a little higher maybe 2mm at most, because I had to drill higher on that side, but the actual tabs were adjustable so it runs flat with the bottom so I'm happy
                        • martin
                          • 2869
                          #87
                          You want tabs mounted around 2mm up from the bottom & not level with the hull bottom.
                          • Drax21
                            • Jul 2011
                            • 1021
                            #88
                            There are only level when I screw them down a bit. Is that ok?
                            • martin
                              • 2869
                              #89
                              Also re the Osprey transome, its 300mm wide & the depth of the flat area ( bottom of v to where the deck join is ) 85mm deep. Overal from the bottom of the v to the actual top of deck its 100mm.
                              • martin
                                • 2869
                                #90
                                They work ok level but you get more drag than having them up a few mm.
