Phil Thomas Supersport 45
  • worriedsick4u
    • Dec 2011
    • 693
    The hull arrived today. Only thing missing is the Virginia Craftsman turnfin and Dick says it'll ship soon. The info sheet Phil sent with the hull is very helpful. Plus Ken (his SS45 is one bad boat) has gratiously offered his help. Bought a Peter Z motor mount. Motor is a Neu 1527/1Y/S/8mm. ESC is a Fightercat 300. I plan on laying out all the hardware then sending it off to Doug for paint. Also not pictured is the Redline Motors stuffing box mount.
    Phil Thomas SS45 001.jpgPhil Thomas SS45 002.jpgPhil Thomas SS45 003.jpgPhil Thomas SS45 004.jpgPhil Thomas SS45 005.jpg
  • Rob DeAngelis
    • Dec 2011
    • 269
    that thing looks AWESOME bud!!!!!! I cant wait to do my first build... Its going to be something big in the 50" to 60" range... mono vee or a cat...
    Lakeside entertainer
    • Espresso
      • Jul 2011
      • 233
      Looks like you got a good collection of parts to start off. What lipo setup are you planning on? 8S1P or 8S2P w/5000mAh I assume?
      • worriedsick4u
        • Dec 2011
        • 693
        Yes I do. Gonna run 6S2P with a X452. Will supposedly do 60+. I hope.
        • LarrysDrifter
          Big Booty Daddy
          • May 2010
          • 3278
          Where do you get the stuffing box mount? Have a link?
          • worriedsick4u
            • Dec 2011
            • 693
            Stuffing box mount. http://shop.redlinemotors.us/Stuffin...l-RLPM-STB.htm
            • LarrysDrifter
              Big Booty Daddy
              • May 2010
              • 3278
              Thanks. Ordered 2 for my PT hulls. Following your build. Good luck.
              • worriedsick4u
                • Dec 2011
                • 693
                Thanks. This is gonna be fun.
                • ksm2001
                  • Jun 2007
                  • 377
                  The hull looks great!! I like that Phil added reinforcement between the two piece floor all the way back to the transom on yours. Mine didn't come that way and had to fill epoxy between to add rigidity for the motor area and the stuffing tube block. Remember to keep the COG 1 inch behind sponson not any further back.
                  Ken
                  DF-29,Phil Thomas Super Sport 45, SV27, Xzess 2 Evo, HOTR 32" Cat
                    • 9479
                    Awesome as I'm tagin along with this one!!
                    • worriedsick4u
                      • Dec 2011
                      • 693
                      Flipping my bracket and rudder to the right side of rudder. Friggin set screws stripped. They were very tight. What's the secret to loosening these without stripping them? No machine shops close enough for me to have them drill the set screws out and re tap them. $40.00 down the drain.
                      • LarrysDrifter
                        Big Booty Daddy
                        • May 2010
                        • 3278
                        Drill them out yourself. Go to LHS and get a tap n die set and some set screws. Very easy to do.
                        • worriedsick4u
                          • Dec 2011
                          • 693
                          Canard template/dry fit. I've seen these in numerous set ups. I was told to give it as much down draft as possible so the nose stays down at high speeds. That's a 28.8 degree which I believe is good. Any thoughts before I cut the canard and apply it?001.jpg002.jpg
                          • ksm2001
                            • Jun 2007
                            • 377
                            That' s a different way of installing the canard. I never thought of it that way, looks great! Are you going to cut out the insides of the sponsons so the canard slides in a bit to each side for extra strength then epoxy?
                            • worriedsick4u
                              • Dec 2011
                              • 693
                              Thanks. And yes I am. I ordered the wider canard. It's 2 3/8" wide. Screwed my rudder up trying to get the damn set screws out. Tried drilling them out and broke a bit off in one. And you know it's impossible to drill through a drill bit.
