MMProducts 39" Deep Vee
  • macdon
    • Jun 2011
    • 970
    #46
    Sleek looking hull!
    About $190 in Rocket City Racing plus $60 shipping to Manila, so $250 for the hull.
    • Alfa Spirit
      • 2131
      #47
      Buy a 4082 motor and sale the 5682
      • iamandrew
        • 577
        #48
        Hey Macdon, yea its definatly a nice hull.
        Its very narrow though, its sort of like a persuit hull but lengthend. so the transom is similar size. Very good build quality. MMP have been good to deal with as well
        • macdon
          • Jun 2011
          • 970
          #49
          Hey Andrew, any feedbacks on this hull handling chop?
          Im currently scratch-building a 40 incher cig boat, but if that doesnt pan out its good to have alternatives.
          • iamandrew
            • 577
            #50
            well in some of the youtube videos its usually pretty flat. the V hull angle is almost the same as the persuit.
            When mines built ill end up using it in a salt water lake.
            The hatch is amazing. its a PERFECT fit. its got less than a 1mm gap around the whole thing, and the hatch bit that slides into the hull is quite deep, so if its taped down you probably wouldnt need hatch locks at all.
            • macdon
              • Jun 2011
              • 970
              #51
              I found 2 videos of it in chop.........
              This next video has chop starting at 6:34
              • iamandrew
                • 577
                #52
                yeah its hard to tell, it really does look like it bounces around a lot. its still almost a 1M long hull thou
                • Alfa Spirit
                  • 2131
                  #53
                  The RAPID has an exemplary behavior
                  • Make-a-Wake
                    FE Rules!
                    • 5557
                    #54
                    The COG is too far back in that vid
                    • Alfa Spirit
                      • 2131
                      #55
                      I' m agree
                      • Alfa Spirit
                        • 2131
                        #56
                        I rectified the rudder blades they are 5cm shorter, now there is 3 or 4cm between the V and the ends of rudders
                        All parts were disassenbled, Rudders are are nicely mounted
                        • Alfa Spirit
                          • 2131
                          #57
                          • Rumdog
                            • 6453
                            #58
                            uhhh, didnt you put a windshield decal on?
                            Start drilling!!!!!
                            • Alfa Spirit
                              • 2131
                              #59
                              What is minimum distance between the blades?
                              If the blades are too much spaced this is not nice, 80mm between the rudders looks nice with the design of the deep vee
                              • Alfa Spirit
                                • 2131
                                #60
                                No idea
