Hey Macdon, yea its definatly a nice hull.
Its very narrow though, its sort of like a persuit hull but lengthend. so the transom is similar size. Very good build quality. MMP have been good to deal with as well
Hey Andrew, any feedbacks on this hull handling chop?
Im currently scratch-building a 40 incher cig boat, but if that doesnt pan out its good to have alternatives.
well in some of the youtube videos its usually pretty flat. the V hull angle is almost the same as the persuit.
When mines built ill end up using it in a salt water lake.
The hatch is amazing. its a PERFECT fit. its got less than a 1mm gap around the whole thing, and the hatch bit that slides into the hull is quite deep, so if its taped down you probably wouldnt need hatch locks at all.
I rectified the rudder blades they are 5cm shorter, now there is 3 or 4cm between the V and the ends of rudders
All parts were disassenbled, Rudders are are nicely mounted
What is minimum distance between the blades?
If the blades are too much spaced this is not nice, 80mm between the rudders looks nice with the design of the deep vee
