Darin's P-Limited OPC Lynx build
always jealous of darins builds..see my fleet
: http://forums.offshoreelectrics.com/...hp?albumid=294Comment
So nice to see when a plan (build) comes together. But even nicer is to hear of some good racing action to counterract the mumbo-jumbo of the keyboard insurgencies . Congrat's to You & Brian & the others who raced. Thanks for putting it into some welcome reporting.
Toby's got it RIGHT
Looks like Jerry Dunlap did it again! Got some fun shots from the races... Was going to wait to paint the hull until after I got the boat sorted a bit and decided if it was going to work or not...
I'm planning the paint now!
Darin E. Jordan - Renton, WA
For a few weeks now, I've been trying to make my own mold so I could lay-up a Carbon fiber battery/ESC cover for this Lynx that would be something more than just the flat cover that I have on it now. Just wanted more room above the battery/ESC so I can have more combination options in the future, and also to make it easier to tape down.
After TWO previous attempts, and with a LOT of help and advice and shopping lists from Brian, I finally pulled a mold that will work!
Has one small spot in a non-critical area (area will be trimmed out after the part is made, you can see it at the top-left portion of the mold) that chipped and left a piece behind on the plug, but otherwise, I think I have a clean mold to work from.
I'm going to attempt to pull a part from it tomorrow and see how it turns out.Darin E. Jordan - Renton, WA
Thought I'd share a pic of the finished battery/ESC cover. Turned out pretty good for my first molding experience. The finish isn't perfect, but I'm told when you vacuum bag, that can often be the case.
I ran the boat this weekend and the extra room over the battery REALLY helped a lot. Makes taping very easy and I couldn't be happier with the way it turned out.
I may re-do the battery access area to give me a little more room to get the cells in and out, but otherwise, this boat is ready for paint. Ran great this weekend!!Darin E. Jordan - Renton, WA
Came out realy nice
. Good idea on the connectors; I've thought of doing that myself to solve sealing issues-motor/speedy replacement. Does the extra set of connectors generate any additional heat ? - just curious.
I did that same thing with the connection from motor to esc a while back when I did an aeromarine predator. It worked out good for me. No excessive heat in my caseComment
Thanks, Tony...
Excessive heat?? Well... I don't know... The motor has yet to come back over 100-degrees, so I'm not sure I'm actually pushing it yet... Average amp-draw thus far is 86-amps... and it seems to be VERY fast just like it is. Wires are all very short, so I really don't think I'm losing anything through those connectors. It sure makes life much easier!Darin E. Jordan - Renton, WA
Good, that settles it. Next tunnel I build will use that connector configuration ( I actually have some "dual" connectors I made for my last tunnel which I didn't use). Now if I can only find ROOM for another boat in my tiny apartmentThanks, Tony...
Tony, I also used REALLY big wire for the pass-throughs... I think it's 8-awg... scraps from a Castle ICE 200... :D I'm still using 5.5 contacts on my motor wires... haven't really seen a need to change them to 6.5's yet, but perhaps in the future... That's a LOT of soldering and swap-out to have to do!
Actually the way I was going to do it was just to have two connectors soldered back-to-back and installed on the back of the box to allow access from the speedy and motor - no wires between the connectors. I need to build a new tunnel; my Herb Stewart is just too darn heavy at 30" (unless a P-OPC class ever emergesTony, I also used REALLY big wire for the pass-throughs... I think it's 8-awg... scraps from a Castle ICE 200... :D I'm still using 5.5 contacts on my motor wires... haven't really seen a need to change them to 6.5's yet, but perhaps in the future... That's a LOT of soldering and swap-out to have to do!
) Right now I'm thinking TS-3 for the simplicity and price - I like the ML295 but me & wood boats (and the buoey in turn one at Legg) don't get along.
Tony,
The Lynx is a 30" boat... :D
As we've both seen, it's hard to beat a well-setup TS-3, especially for the price.
I'd still love to see what I could do with a Stiletto if I could get one made that was about 2lbs lighter. I think it's a good design, that would work well if it were just a little lighter.Darin E. Jordan - Renton, WA
